@Portisch
It works with 4.0.7. I can test it with 4.0.5 as You wish.
Issue:
CEC didn’t work at all (with my Panasonic). I have Ugoos X2 Cube with dualboot CE/Android. In both systems CEC didn’t work at all. In CE after boot notification was appearing that modul CEC hadn’t been initialized. In previous releases up to 9.2.2 CEC worked out of box.
Hi. I have an x96 air and in the latest version of coreelec I disable the cec wake-up option and when I exit the configuration and re-enter it is activated again. It must be some kind of bug. Is there any other way to disable it?
