A question about Bluetooth connection
Tencent Aurora 5x
coreelec 21.2
After installing coreelec, the system enters normally, but the Bluetooth remote control cannot be used after connection. The log shows as shown in the figure. After successful connection, it can be used briefly for a few seconds, and then the buttons have no response. However, the settings show that the Bluetooth connection is normal
text
2025-10-02 16:09:18.287 T:1283    error <general>: ## CoreELEC Addon ## bluetooth::show_options ## ERROR: (AttributeError("'bluetooth' object has no attribute 'disconnect_device'"))
2025-10-02 16:10:04.703 T:1347    error <general>: ## CoreELEC Addon ## bluetooth::show_options ## ERROR: (AttributeError("'bluetooth' object has no attribute 'disconnect_device'"))
text
2025-10-02 16:14:26.110 T:1255    error <general>: ## CoreELEC Addon ## bluetooth::start_discovery ## ERROR: (DBusException('The name :1.7 was not provided by any .service files'))
2025-10-02 16:14:57.332 T:1615    error <general>: ## CoreELEC Addon ## bluetooth::stop_discovery ## ERROR: (DBusException('No discovery started'))
kodi.log (44.6 KB)
BT just sucks. Sometimes works, sometimes not.
More luck is with external BT USB dongle.
Which chip is the most suitable
This adapter is natively supported in Kernel 5.14.x so works great with CE-NO.
There is a v3 version of this adapter that I have not tested so can’t confirm about that one. v1 certainly works
I bought a Bluetooth 5.4 Nano USB Adapter (ver.3) and it works with CE22 NO.
tp1
tp2
Hello, if you can start CE normally when using two USB storage devices at the same time?
