Ok, I didn’t find the way to set SMB share, so I have tested with Kodi 22 nightly, and it works close to Fire TV but no FEL is working under Ugoos OS (with Kodi).
Still when set LLDV through vertex2 (because it acts to tell player that it’s a DV), I have a blank screen most of the time, my projector didn’t find the signal.
So in final Android is near working OK on Ugoos but LLDV failed handshake or something because I was able to have LLDV but not always.
Removed by author
In fact like the projector is not DV, I can’t set TV ou Player LED, and with HD Fury, only Player LED is available and greyed because there is only that choice like projector or Vertex2 can’t do the DV decoding.
DV settings are present only if a display is DV compatible.
FireTV can be set as DV (player LED aka LLDV as always) and it rocks, CE can’t do the same.
Ugoos OS reacted the same except that here is handshake issue with the Vertex2 and no clue why, must be software issue.
Thanks anyway ![]()
Get a DV capable device and all issues are gone.
There is a reason why the vendors need to pay for a DV license.
Get real DV or cheat it somehow - but this is on your own.
CE can do what you want but it looks like you don’t search correct in settings and/or forum.
Like using the keyword EDID…
Removed by Author
Thank you for the idea about EDID, I just bought my projector, so you understand that I can’t change it right now, but it could be an idea and DV on projector are mostly on DLP and I can’t go with it with Rainbow Effect, so I have take the way on 3LCD.
Thank you Freddy, I will read it, I didn’t know that it was possible, why I have explained if it was possible, effectively I didn’t have this lead until now ![]()
Got vertex 2 solved my problem. Hdr looks so good its tone mapping seems to be like DV. Am6b plus is sensitive with 4k hdmi.
I have one problem i just niticed dolby atmos pause for a second after sometimes
Nice that Vertex2 it’s works better ![]()
For the audio no clue but maybe change audio device in CoreELEC, in Vertex2 audio should works good
I may try different settings for audio. I thought CE dropping audio. Just confirming if you experienced same issure in vertex2
First i used ultra speed hdmi picture ce to vertex was like golden / warm color than changed it to 4k hdmi cable. This thing is hdmi sensitive (am6b+)
There is an issue with ATMOS from Kodi, not sure if it’s the one you have but it’s possible.
Megan 2.0 has that à 3 minutes 22 for ex, but it should happen with or without Vertex2 if related to Atmos bug.
I need to test more on CE, but on FireTV and vertex2 no issue except the Kodi but like above.
With atmos Sound pause for a sec quite often specially in HDR videos.
Truehd is worse
@vpeter
Try to grab some logs to see if it’s visible in it ![]()
This thread is really like a big spaghetti spam ![]()
I could not figure out how to create logs but sorted the issue. Thanks
Please open a thread at Kodi forum and explain all the issues there. I would really like to see the response from Kodi devs.
And please, stop with this nonsense posts here because they are just a spam.
It’s your total incompetence that sent your SK1 back in the box. Don’t confuse or identify yourself with competent users which are completely satisfied with SK1 running on CE-NO with Kodi 22.
Guys, calm down & BTT, please…
I had tested ce 22. Way more stable in respect of framerate but not perfect. Dv tonemapping is not good. I have noticed in every build. Hdr adjustment does more harm than good
Thanks for reporting, yes the refresh rate part seems to be better ![]()
