AM6B+, DV picture to warm
What is RRC?
How do you disable DV 8.1 in android?
Does FEL works fine in CE.
Use NG 1020 . 1023 is not stable color wise… what build are you using?
@Sebastiii would you like to tell Is there any difference between soc 922 and 928 graphic and picture quality wise?
@vpeter @Portisch NG 20251023 is not stable colorwise and frame rate. 1020 is very stable and very nicer colors. just let you know guys
STOP mentioning my name if not needed! I have zero knowledge about this issue.
Changelog (20251023)
As you can see there was no commit which could change anything you mention. Only openssl. Please explain this.
RRC is the refresh rate changer, under Video settings to match the frame of the video :slight_smile:
Always under Video (expert settings) there is a switch (mode compatibility Dolby Vision) and with it enable, it transforms Profile 7 to 8.1
Yes, FEL works in CE-NG, not on CE-NO.
About color, I didn’t notice something weird when I have tested, it was a nightly CE-NG.
I have no clue about the diff in the soc 922 and 928 graphic.
For sure, Ugoos player handle DV in a better way because RRC has no impact on it, but it’s not Kodi, etc. I think it’s surely doable to do the same under CE, it will avoid a handshake less when RRC should not be started.
But it seems on Kodi, the way to recreate the window need to be like that (Kodi or CE part of Kodi).
You can set Kodi (in Android) to use an external player; then set prefered Ugoos player as external.
If this is turning in an Ugoos android topic please take it to unsupported/offtopic or to XDA forum. Thanks.
Yes it can be possible but better to use the native one and talking about Android version is for the comparison to see how it goes there so better to stick to CE with maybe a handle different or not.
Thanks for the idea :wink:
You are right, it’s not to turn to Ugoos Android but to know how it works there to try to have the same on CE :wink:
Where we know what can be done on the same hardware, then it surely possible to achieve the same.
Don’t want to use Android version but CE one of course
PR is welcome, just talking is cheap.
Hi . I could not find DV compatiblity dolby vision where it transforms profile 7 and 8.1. not even NG nor NO
Does it have to do specific dovi file?
Ah sorry, this option, is on Android build :wink:
So you are right, on CE, it is managed directly :+1:(so no options on it)
you mean if I install Kodi in android than there is option to select between profile 7 and 8.1 ?
When there’s no option, no option is needed. Please don’t make me close another thread.
does guisettings. xml contain EDID settings?
I just installed 1102 NO. Colors were too warm until I changed the HDCP 1.4 and back to 2.2 .
This is regarding NO 1102 . Every time I switch on ce color gets warmer and warmer. If i try change setting or touch HDCP or color range than it effects framerate and does not play smoothly anymore unless reinstall all again
I installed 21.3 ng and I’d always had poor picture quality distorted colours and jitters. Finally, I tried something: I downloaded EDID from my TV through Vertex HD Fury and loaded it in vertex right before powering on CE NG. Now I have good smooth picture quality and good playback. Any long term solution?
I also noticed after a few days that installing NG increased the brightness of the DV. Why doesn’t it do that right after installation?
@Portisch @freddy @vpeter
Use CE-NO, there is a EDID dump feature included.
Or search forum, I think there is somewhere a solution to fake EDID on CE-NG.
How to dump edid in ce no?
