No, we’ll create a package for the addon in CE repo. It’ll use your github repo to pull it.
Ok thanks, now I understand
Pull request has been submitted.
KIII PRO MECOOL CE 9.0.1 work how to charm and on tv too.
Thank you so much
Thanks for the PR. We are reviewing it.
The latest update devel-1555226781 has broken the addon by changing output of cat /sys/class/amhdmitx/amhdmitx0/config
And with autoupdate forced on I’m kind of screwed
Awesome work, Roidy! I’m using Estuary MOD V2 as Ray too so looking forward to use the addon when I get back from vacation
https://test.coreelec.org/ray/CoreELEC-Amlogic-ng.arm-9.0-devel-1555227411_cscd_auto.tar
It’s the same version + @cdu13a patches
I will be merging changes to /sys/class/amhdmitx/amhdmitx0/config soon. Until then the addon won’t work properly with out using one of my patches I made for testing.
Nice Idea, and nice work by the way.
I can relate on the frustration with the autoupdate. I had an unfortunate damn it updated on me a couple hours ago.
Ok thanks guys, No problem I totally understand things are a bit all over the place right now with different test versions.
And what about addon for kodi android?
I’m looked config into /sys/devices/virtual/amhdmitx/amhdmitx0/config
on my X96 Max, but it hasn’t information about color depth
sorry if offtop…
Because we patched hdmi code. Sorry but it will not be possible.
/sys/devices/virtual/amhdmitx/amhdmitx0/attr has info about bit rate and depth, but it’s in one line, separated by commas…
hmmm. I hacked this for skin.confluence but it looks like it’s all jumbled at the top. Any thoughts?
@roidy I’ve pushed the required changes to the kernel. So this should start working with every new build for the N2 soon.
@anon16105386
You have to change control type=“grouplist” to control type=“group” and also to adjust the left and top values.
@anon16105386 Sorry I don’t use Confluence and I’m not familiar with the code.
@cdu13a Good to hear, thank you
After I will be back from vacation, I will try adapt this also for confluence. If someone doesnt do that already meanwhile
We could do PR for CE also for Confluence then
Confluence is not part of the XBMC repo anymore, and is not pre-installed with Kodi.
I don’t really see how you can PR this CE-only change to the Confluence repo.
