Amlogic Hardware Decoder is not always working
Hi, is there any further thread/reply on this topic? i have Wetek Play 2 (s905h ver c) and the issues I get with 9.2.2 and 9.2.1 are exactly same as described above. Shall I downgrade back to 9.2.0? Thank you.
CE devs need samples and logs to reproduce the issues you are having. Follow How to report an issue you're having with CoreELEC and provide us with samples so we can test this as well
I hoped for having this already tested since 2-3 months time. There were logs submitted but I could not see any feedback.
I just downgraded and the issue appeared in 9.2.0 also.
I will get the logs, but if in the meantime there would be any progress/experience since last logs I would appreciate it.
Same problem with my X96 mini 2/16 S905W since CE 9.2.1 and latest (9.2.3).
Black screen with h264 content (PVR IPTV Simple Client).
If I disable h264 accelerate the problem disappear but the video play with lag.
If I enable the h264 accelerate with kodi started or reboot the device the content play works well.
I prefer to stay in CoreELEC 9.2.0 becase works well but the update message it’s annoying, all the time I power on the device…
[EDIT] No hint to avoid update…
I’ve got too a H96 Max x2 (S905X2) with 9.2.2 or 9.2.3 and no problem.
There’s a bug in the old releases which makes disabling the update popup impossible.
