@Portisch
Could you help me figure out why the box is behaving like this?
I think it is because of the kernel.
The CE22 NO alpha1 works good.
The nigthlys from the summer are also good.
CE19 is good.
When I restart the box from the menu, it immediately switches to 60Hz.
But after restart the menu shows 50hz. So it is perfect. But it is strange at first sight.
But when I turn on the box with remote controller, and the system boots up, it switches to 60Hz again. (I need 50Hz)
What kind of log do you need?
It is a fresh log.
https://paste.coreelec.org/BanishedHarris
Do you see my problem through the logs?
Thank you for your help
I have a Tanix W2 box (s905w2), and since changing the kernel to 5.15.170,
the box has been stuck in a boot loop.
Here are the logs from the UART port: boot-s905w2-CENO - Pastebin.com
It works fine on the nightly version 20250903.
Please downgrade again before 5.15.170. I think last version was 20250904.
Then enable tmate session and leave the device running and connected to the internet.
Also disable automatic update in CE settings as otherwise it will update to last nightly again.
We will then try and search what will cause this issue.
Version 20250903 installed.
New basic installation.
Tmate session configured and running.
Thank you!
Connection to lon1.tmate.io closed.
I restarted.
Nov 05 19:18:04 CoreELEC sh[1174]: Error reading from channel: Socket error: Connection timed out
Nov 05 19:18:04 CoreELEC sh[1174]: Reconnecting...
Nov 05 19:18:06 CoreELEC sh[1174]: Error connecting: Failed to connect: Network is unreachable
Nov 05 19:18:06 CoreELEC sh[1174]: Reconnecting...
Nov 05 19:18:08 CoreELEC sh[1174]: fatal: Cannot initialize the DNS lookup service
Nov 05 19:18:08 CoreELEC systemd[1]: tmate.service: Main process exited, code=exited, status=1/FAILURE
Nov 05 19:18:08 CoreELEC systemd[1]: tmate.service: Failed with result 'exit-code'.
Nov 05 20:01:26 CoreELEC systemd[1]: Starting tmate.service...
Nov 05 20:01:26 CoreELEC tmate-pre.sh[1706]:   % Total    % Received % Xferd  Average Speed   Time    Time     Time  Current
Nov 05 20:01:26 CoreELEC tmate-pre.sh[1706]:                                  Dload  Upload   Total   Spent    Left  Speed
Nov 05 20:01:27 CoreELEC tmate-pre.sh[1706]: [158B blob data]
Nov 05 20:01:27 CoreELEC systemd[1]: Started tmate.service.
Nov 05 20:01:27 CoreELEC sh[1710]: To connect to the session locally, run: tmate -S /var/run/tmate.sock attach
Nov 05 20:01:27 CoreELEC sh[1710]: Using /var/run/tmate_id_ed25519_ce.pub for access control
Nov 05 20:01:27 CoreELEC sh[1710]: Connecting to ssh.tmate.io...
Nov 05 20:01:28 CoreELEC sh[1710]: ssh session read only: ssh ro-3FKL9YHQSeJVKcBreEGTzBfQv@lon1.tmate.io
Nov 05 20:01:28 CoreELEC sh[1710]: ssh session: ssh 7h8WmU8SDRnMcxedDqxmEHVbd@lon1.tmate.io
Nov 05 20:01:28 CoreELEC sh[1710]: Temporary server error, tmate will reconnect
Nov 05 20:01:28 CoreELEC sh[1710]: Error reading from channel: Socket error: disconnected
Nov 05 20:01:28 CoreELEC sh[1710]: Reconnecting...
Nov 05 20:01:31 CoreELEC sh[1710]: Reconnected
EDIT:
I see it’s already working on the new kernel version 5.15.170.
I’ve connected it with an Ethernet cable now, it shouldn’t disappear.
https://paste.coreelec.org/BeganVinc
eth0 is working but CEC not working
device is connected
Done, thank you!
Is this a problem between CE NO and Kodi?
When I launched Kodi, the system went into a bootloop again.
S4, S905Y4 and S905W2 is not working with 5.15.170 anymore.
No idea when it get working again…
I understand, what I need works on version 220250903.
Thank you for trying to help!
Really liking the new HDR to DV option but it occasionally results in an extremely washed out display that persists even when stopping the video, a reboot is required to get the display back to normal.
This is on a Homatics box r 4k plus on the 20251108 build.
It’s same with sk1…
Yeah…I dont recommend using that. If you want to watch DV stuff, then watch DV. Forcing DV on something is not a good idea and you get the results you see
Yes ,have seen the same on X96X10 Pro, occasionally, Playback a Dolby Vision file for a few seconds, seems to refresh EDID,UI,so noneed to power cycle the Box
@Secam7 S4, S905Y4, S905W2, 2GB RAM should start working again with next nightly 20251118.
Every now and then when I play a 4k file on my X96 X10, it comes up in 1080p, but only showing the top-left quarter of the 4k screen.
It’s weird, even the kodi info overlays, (I use confluence theme so the timeline is at the bottom of the screen) are cut off the screen although I can see the dimming at the top.
It’s always resolved by a reboot, or sometimes by playing another video file to “reset” the HDMI resolution.
Anyone else seeing this behavior?
Do not restore a settings backup from older installation.
Try again with clean, fresh install.
252 / 5.000
Hi, I have a GT-King 922x device and have been having Wi-Fi problems for a few weeks. After starting up, the Wi-Fi connection drops. When I reconnect, it stays active. There’s no problem with the wired connection. Does anyone know a solution?
