I will need to get tmate access to find the reason of g12a fail again with new kernel.
So you never get Kodi up on newest nightly?
That Kodi attempt to start again you will need to run sc unmask kodi.
The. sc start kodi. When Kodi is starting enable tmate remote access in CE settings and ensure it’s connected by ethernet to internet.
If kodi will not start at all keep it masked by sc mask kodi.
Then by SSH:
echo -e 'TMATE_INVITE=true\nTMATE_SSH_KEY="User key"\nTMATE_USERNAME="as_id"' > /storage/.cache/services/tmate.conf
sc start tmate
“as_id” connection name
I see it, what is the eth chip? Or is it 100MBit?
Cable is connected I guess.
S905x2 4GB 1Gbit
ps. cable is connected
I will update and reboot the device some times
Okay, do whatever you need to do.
With old kernel there is no eth at all:
Linux version: 5.15.153 (docker@e84134c40c48) #1 Wed Sep 3 01:32:32 IDT 20
Yes, it’s true, now was downloaded auto update last nightly, may be need delete it?
ps. I was off autoupdate
I update to last nightly. After update please boot into Android and get like by adb this info:
adb connect 192.......
adb shell
cat /sys/kernel/debug/gpio
And dmesg also when possible. If this is not possible start adb bugreport and share the bugreport zip.
Like by adb shell:
adb bugreport
For me it looks like ethernet never worked on CE-NO on g12a devices…
:confused: $ cat /sys/kernel/debug/gpio
gpiochip1: GPIOs 410-495, parent: platform/pinctrl@ff634480, periphs-banks:
gpio-445 ( |amlsd ) out hi
gpio-458 ( |amlsd ) in lo
gpio-474 ( |vdftest ) out hi
gpio-475 ( |vdftest ) out hi
gpio-482 ( |sdio_wifi ) out hi
gpio-483 ( |sdio_wifi ) in hi
gpio-493 ( |bt_rfkill ) out hi
gpio-495 ( |bt_rfkill ) out hi
gpiochip0: GPIOs 496-511, parent: platform/pinctrl@ff800014, aobus-banks:
gpio-498 ( |avout_mute ) out hi
gpio-499 ( |key
) in hi
gpio-506 ( |vdftest ) out lo
gpio-507 ( |?
) out hi
dmesg.txt (282.1 KB)
br.zip (1.6 MB)
You need to end adb shell and just run adb bugreport then you get a zip file in this folder where you did run the cmd.
ok, please setup tmate again with latest nightly
done…………………………………..
Please try again until it’s running.
Connection is closed. Or you need to mask kodi again?
@as_id device is still offline.
Now device online, but it can go to sleep, if you can turn off sleep mode, I’m don’t know how to
https://kodi.wiki/view/Settings/System/Power_saving
shutdown function timer: OFF
Yes, it shows off but turns off after some time
@as_id it is fixed now and the fix should be included in next nightly.
I disabled tmate now.
hello, i have the ugoos am6b+, is there a dovi.ko for this build? i’d like to try it out. thanks a lot coreELEC team.
yes, search the forum
