Using the latest build in amb6+. Has wake on lan broken? I can’t get it to work, does the Kodi box needs to be suspended for it to work or can I shutdown it down. Worked fine in the ng release
The ancient, un-upgraded Kodi installed on the TV can display mpls normally.
Correct, some other devices could also be affected. Will be fixed in next nightly build.
And ethernet is also broken on X96 M300 and some other devices for some time now. Looks like no one is using it and this would mean no need to fix it.
Recently, some hot Estonian guy installed DEBIAN on his Dune PV4K :grin: And soon after, he successfully bricked it. He was only able to recover it for using only for CoreELEC, with no DuneOS. So never underestimate human stupidity and free time.
The same story with people who are not satisfied with the original CoreELEC and they CONSTANTLY search, install and discuss various mods, 2.8% smoother, 14.2% faster, 11.6% more accurate DV, 0.12% more accurate HDR, or those that lose 1 frame per million frames less than the original CE. For them, it’s like a full-time job. It’s not even perfectionism anymore.
I’m not able to get WoL to work on the AM9 Pro, either (via ethernet).
I have M11Max S905X5M ,and have been using X96M300 for Android Base.
No issues with Ethernet ever.yes wifi is down since last nightly.Bluetooth is fine .
Rtl88x2cs think is driver for wifi.
Thx for fix in next nightly
WOL will maybe not be supported by bootloader, ask Ugoos.
With the 20260608 build, emulator addons don’t work anymore as the libretro compatibility addon is incompatible.
CE (COREELEC) is just enough OS for KODI. It boots into Kodi.
Android Kodi also can’t find the required mpls
Has the current CE/LE SDR GUI already been mapped to the HDR GUI?
This is currently not need by CoreELEC. We use vendor kernel and the OSD tone mapping from BT.709 to BT.2020 is done automatic by hardware, not software.
Only the PQ setting is need to dimm the OSD a bit, depends on used TV.
Finally HDR10+ is detected correct:
And it also work for ISO now:
I see now..
Don’t understand the question. ISO is always dual layer…
Was wrong question. I meant the av1 profile 10 DTDL track.
That still broken. Thanks
Like this one from @ragico is working on X96X10 Pro s928x J
:rofl:
There’s a saying for that kind of people : We gave eyes to a blind man, he started to ask for eye brows
I don’t get these people. I currently feel in a state of bliss! I bought a long time ago a DuneHD BoxR 4K and through out all the updates, I have now something like a dream machine which, with the huge help of CoreELEC displays 4K HDR/HDR10+/DV movies with DTS-MA/DTS-X/DolbyTrueHD/DolbyAtmos sound direct to my AVR while sipping 4W of energy.
AndroidTV is still 11 or 12 as it was out the box, never cared, never used it and I don’t intend to. CoreELEC is the sole use of this box and there’s absolutely NOTHING appealing elsewhere to replace it, both the box and CE!
I have latest nightly build running on Homatics Box R 4K Plus and noticed that kodi.bin uses almost 100% of CPU time when HDMI is plugged off (AV receiver turned off). Once I plug HDMI back, kodi’s usage is at few percent. The box is supposed to be idle at that time.
I didn’t have this problem with official 21.3-Omega NG build.
Is this known issue? Anything I can do about it?
Right this moment, my DuneHD Homatics BoxR 4K is alive but my AVR is in standby mode, although it supports HDMI source bypass in standby mode, and my TV is also in standby mode.
htop reports ~6% CPU usage for kodi with spikes to ~10% every few seconds only because the skin I use, AeonNox SiLVO uses a directory for backgrounds for each main menu item and cycles through them.
S905X4 in the BoxR being an underpowered CPU, it creates a tiny bit of load to cycle through the background pictures.
Other than that, nothing to report about kodi being stuck at 100% CPU.
