Yes, that is correct version; for me it works with Android Pie on eMMC, CE 21-Beta3 on USB stick and CE -no on uSD card. I keep the switch in SPI (multiboot) position all the time.
Another thing I always do when installing some new OS/Version is that I remove all attached media from all inputs and keep only needed installation media in its place - SPI switch is then in eMMC position. After the installation is done I connect all my other media/OS sources and flip the switch to SPI position to select my OS.
PS. Probably now with new kernel 5.15.119 a new Petitboot version will become necessary since the present version was done for 5.15.78…
Unable to select 3840x2160 resolution and the TV restarts.The same error occurs when I want to watch 4K broadcast.
new kernel 5.15.119
Device Gt King II
It’s currently running at 1920x1080.
Note:Resolution 4096x2160P 24 Hz adjustable
A post was merged into an existing topic: New Order: Looking for users with no working WiFi or BT
Resolution 3840x2160
https://paste.coreelec.org/9ZxPjT
4K Live Tv
https://paste.coreelec.org/yqsjSD
I don’t understand and do not see any error in log. It start 2160p50hz.
I’ve tried many times, the same error every time, 2160 resolution does not accept.
When I get to 2160 resolution it switches off the tv and the tv restarts.
Works with 4096x2160p 24 Hz resolution
My Tv TCL 55C745
No problem with GT King Pro
I don’t know if this helps but I have tried 6 different boxes
2 ea. s905x2
2 ea. s905x3
1 ea Khadas Vim4
1 ea Libre Alta
None of the will do 2160p60hz when I try to select this I get a blank screen then it reverts to 1080p with a ERROR clk div40 failed!!
Log below
[ 2086.592667] [drm] am_meson_drm_fb_helper_set_par IN
[ 2086.592686] [drm] fb_set_par: am_meson_drm_fb_helper_set_par OUT
[ 2086.618714] [drm] [meson_hdmitx_encoder_atomic_disable]
[ 2086.619333] [drm] am_meson_crtc_atomic_disable-[0]:in
[ 2086.624858] [drm] am_meson_crtc_atomic_enable-[0] in: new[2160p60hz], old[1080p60hz], vmode[4-4], uboot[0]
[ 2086.634317] [drm] am_meson_crtc_atomic_enable-[0]: enable mode 2160p60hz final vmode 0
[ 2086.645629] [hdmitx:] display colour subsampling is forced to YUV420 because of current video information code 97
[ 2086.657087] [hdmitx:] display colour subsampling is auto set to YUV420 (VIC: 97)
[ 2086.662821] [hdmitx:] display colourdepth is auto set to 8 bits (VIC: 97)
[ 2086.668016] [hdmitx:] *ERROR* clk div40 failed!!
[ 2086.671016] [hdmitx:] format_para: frl_rate 0
[ 2086.675296] [hdmitx:] format_para: ffffff80d3b21bb0 vic [97]
[ 2086.675296] format_para: name 2160p60hz frac 0
[ 2086.675296] format_para: colorspace: 420, colordepth: 8bit
[ 2086.675296] format_para: TMDS 742500 DIV40 1,1
[ 2086.695313] [hdmitx:] div40: 1
[ 2086.727502] [hdmitx:] frac_rate = 0
[ 2086.727547] [hdmitx:] config HPLL = 5940000 frac_rate = 0
[ 2086.731279] [hdmitx:] HPLLv1: 0xdb3a04f7
[ 2086.734821] [hdmitx:] set enc for VIC: 97
[ 2086.738869] [hdmitx:]  config hdmitx IP vic = 97 cd:4 cs: 3
[ 2086.797497] [hdmitx:] Sink is HDMI device
[ 2086.797604] [hdmitx:] fs = 2, cd = 4, tmds_clk = 297000
[ 2086.801395] [hdmitx:] update audio N 4707
In addition It doesn’t recognise colour depth. (Eoft and Gam)
Maybe there is something wrong with auto cd/cs:
Here it’s
[   64.010071] [hdmitx:] display colour subsampling is forced to YUV420 because of current video information code 97
[   64.010074] [hdmitx:] display colour subsampling is auto set to YUV420 (VIC: 97)
[   64.010078] [hdmitx:] display colourdepth is auto set to 12 bits (VIC: 97)
But it should be limited to 10bits anyway.
The bad thing: I can confirm it doesn’t work. It depends on TV.
The good thing: I can reproduce it here with your EDID & Vertex @crazyturk.
So I should be able to debug it. It was working with 5.15.78, isn’t it?
It’s TV dependent, works okay with Panasonic HZ1000 oled
https://paste.coreelec.org/9ehfb9
This is might the problem :wink:
2160P240 420 BT709 10b SDR 371MHz
Yes, all videos work as colour depth 10 bit yuv444 and eoft sdr bt.709.
colour depth 12 bit
colour subsampling 4:4:4
videos work corrupted when set to
Can the Android version on the device cause the error?
A similar error due to the Android version has occurred on other devices before, but not on my device.
I am using the Android beta version given from the Beelink forum
i found same code in my paste , although i don’t understand this.
I also changed the android version on the device, same error
display resolution and white list 3840x2160 30 hz works when set, but stuttering occurs in the image.
Does not work when 50 hz is applied.
In all videos Eoft and Gam always show SDR BT.709
Always Colour depth is also 10-bit, YUV444
The new nightly build 20240221 on my s905w2 box restarts when I try to enter the CE menu
and other places, e.g. add-ons. I am attaching dmesg: https://paste.coreelec.org/lXVGhm
Any memory allocation issues?
