I see nothing in dmesg.
Please make a dmesg log from Amlogic-ne, CE-21.
And Kodi.log from Amlogic-no. Enable Kodi debug before enter a window by CTRL-d.
Should be fixed with today nightly.
Thanks, now it works fine.
Amlogic-ne dmesg: https://paste.coreelec.org/O8bOvD
In this version the box works properly.
In version 2024022 you can now enter the CE menu.
An attempt to install a language pack ends with a restart of the box.
Kodi.log: https://paste.coreelec.org/Da7bOJ
Kodi.old.log: https://paste.coreelec.org/TYmMqX
 error <general>: CAddonInfoBuilder::Generate: Unable to load '/storage/.kodi/addons/resource.language.pl_pl/addon.xml', Line 0
                                                   Failed to open file
This doesn’t look correct. Remove addon, reboot and install it again.
In all 4K broadcasts, there is image distortion in the vertical section on the bottom edge and right side of the television.
No log, no info, no problem
![WhatsApp Görsel 2024-02-22 saat 19.47.28_28743021|690x318](upload://ni69ICtgfdx3u8YwL33GU34adBv.jpeg
my device ugoos AM7 905X4
Still no log…
kodi.log (1.3 MB
paste
https://paste.coreelec.org/4eu81v
I give up, just boot and make dmesg log
This is just the result of a failed installation of this add-on.
I made a new installation of 20240222 and the box still restarts when operating on add-ons.
Next logs:
kodi.old.log: https://paste.coreelec.org/yFOxMp
kodi.log: https://paste.coreelec.org/kieVAS
I don’t understand much but I can turn on terminal sharing for remote management
Please do so, I will take a look later
Device restarts or Kodi restarts? Is there also crash log in kodi temp folder?
Also those logs adoesn’t have DEBUG enabled in kodi.
I turned on terminal sharing.
Devices restarts, therefore the end of the logo is illegible, as here:
2024-02-22 16:26:52.077 T:1233    error <general>: ## CoreELEC Addon ## connman::dbus_error_handler ## ERROR: (Did not receive a reply. Possible causes include: the remote application did not send a reply, the message bus security policy blocked the reply, the reply timeout expired, or the network connection was broken.)
There was a crash log, but of 0 length, probably because of the above.
I did this:
I installed polish addon and works ok without any crash. At least on Khadas VIM4N.
You need to write exactly the steps you do from main kodi window.
@tornaci I placed a update on your device. Please reboot and try again after the update.
Thank you but the error persists
