I pinged him already, will see how it works.
Addons should now be available. If some of it doesn’t work then try again tomorrow where all of them wil be rebuild.
He did that already → Amlogic-no Discussion - #1115 by Bindou
For me it feels same. So without currently “measure” it there is nothing we can do.
crazyturk, run this command in ssh console
echo "blacklist wifi_dummy" >> /storage/.config/modprobe.d/blacklist.conf
and after reboot wifi should work.
Thanks, wifi works with this command.
Greetings,
Dad, when will you merge this with the nightly image?
Best regards…
I am trying CE-NO on the ugoos am6bplus and am quite impressed by the DV quality expecially P5 files.
I cannot find the “time zone” setting. Is it been removed from the CE NO?
It should be already included. Tuner doesn’t work? Then post dmesg after reboot.
It is moved under CoreELEC settings / System: coreelec:ce_addon_system [CoreELEC Wiki]
I pushed the changes but linux was not bumped. Will do it today and next nightly should have fix included.
With update petitboot to 20231218 CE 20241230 do boot normal from eMMC without any issue!
Do you have any tips how to get better data for analysis and comparison between the kernels?
Amlogic-no Discussion - #1117 by Bindou has something already.
Is there any more information we can provide, or any additional testing we can perform that might be useful in troubleshooting this? Seems to be affecting various different hardware.
It also happens to me on a Transpeed 905x4. I think the problem is the sleep option, then the screen does not turn on again unless it is restarted. Since when I suspend the TV Box from the shutdown option the same thing happens.
No, there is a bug somewhere. Will be solved one day…
Wifi issues on devices using PCIE chips should be fixed with new nightly 20250103.
Unfortunately,
I cannot confirm this, does not start even with spiboot-20231218.img.
No log, no error.
Confirm.
NO Version https://relkai.coreelec.org/Amlogic-no/ce-22/CoreELEC-Amlogic-no.aarch64-22.0-Piers_nightly_20250103-Odroid_N2.img.gz
will not boot - only black screen, no logfile
