Just updated about my situation about video freezes using latest 20250128 release, after i reverted back to 20250120, problems stoped so i guess somthing is wrong with latest nightly for shure
It might help others if you followed the official route to reporting issues.
Hopefully S4, S905Y4, S905W2 SoC will be supported again since nightly 20250201.
I cant find that NO release?
The build server has some issues. Will soon be resolved.
I have been trying the 20250128 version a few times. I can get it to come up on one of my TVs without a problem but a TV with 1600x900 resolution I get Unsupported Video Signal (but can ssh in anyway) using a generic W2 Android TV box with the S905W2 so it does work with that SoC using the s4_s905w2_2g.dtb file (the box is supposed to have 4G ram but I have never been able to get any CoreElec or EmuElec 4G dtb file to work, I suspect it has to do with the fact that in Android some info apps report 2Gigs ram and some report 4Gigs ram so has something to do with the installed ram).
I havenāt had time to do much testing but it does come up and I can navigate around and I have done things like change skin and added weather.
I have noticed that it seems to take a long time to power off but eventually does. I am going to try to get log files for that and submit them.
EDIT: Sorry I didnāt realize this topic was for a newer version. I only see the 20250128 version available so thought it was an older version being discussed.
Last builds were buggy. Also i saw many times that after run retroarch was panasonic TV turn off (this bug was not to build cca 5.1.2024 with identical last retroarch). But i dont have logs from this situations and issues are too much also without it. Also my panasonic TV remote had issue with last builds. So maybe CEC is also broked.
Bug with bad HW acceleration of some video formats and iptv streams is always from using newer kernel 5.15.137 on last build from 5nd february 2025 on am6+.
Latest nightly pops up āCEC installation failedā.
Never seen that one before
This happens on a N2 rev a if that mattersā¦
/Edit: after Kodi restarted from a lockup, it said ācec addon installedā.
Also, if gui refresh differs from content and content is 23.976 MHz, then a black screen / sound reset happens when playing media and then switching to the gui and back while media still playing.
When switching to iptv channel while local content is playing, Kodi sometimes locks up and restarts. First time for that one, too.
Donāt post support requests by using banned addons!
https://kodi.wiki/view/Official:Forum_rules/Banned_add-ons
No support by PM or email!
Make clean fresh install without banned addons and try again.
Just to report with latest nightly the refresh rate switching issue with black screen / sound reset do not occur anymore. Nice!
Unable to activate HDMI-CEC adapter.
Note:I ran it by manually editing the CEC xml file.(/storage/.kodi/userdata/peripheral_data/cec_CEC_Adapter.xml)
With the update received today, the device reboots when entering the repository installation.
Tested devices Gt King II, AM8 and SK1
CE version NO Kodi piers
Note:If the internet is turned off, it works fine.
I noticed several Kodi lockups/restarts just browsing listings in addons with latest nightly.
Short in time for troubleshooting, logs etc but can do some more later if needed.
Same here. Unbranded W2 Android TV box with S905W2. Did the upgrade from the previous version and had to unplug the box to restart 3 times just going navigating menus. Didnāt have time to test.
Same here using a HK1 S905X4. I wish version 20250205 was up.
Regards!
https://archive.coreelec.org/ is back online. 20250204 is last backup.
Looks like I did disconnect the USB drive .
How to reproduce the issue with the repo?
How or what is the issue with CEC?
There was this change: [Peripherals] Last round of enhancements to Peripherals Dialog by garbear Ā· Pull Request #26323 Ā· xbmc/xbmc Ā· GitHub
And I see also now game.controller.cec.adapter
is installed on my device, automatic. Maybe this can cause issues?
More detailed description and how to reproduce is need!
Repo crash should be solved tomorrow:
Thanks to the CE team, everything is fine.
Next extra small sad bug: bad timezone for central Europe on CE22NO with set country Slovakia (in winter time it now showed in coreelec wrong extra 1 hour back). For comparation on CE21NG is it ok.
All member states switch to summer time on the last Sunday in March and back to their standard time (āwinter timeā) on the last Sunday in October.
https://www.consilium.europa.eu/en/policies/seasonal-time-changes/
