Can you please tell which tool is this? Is there a special config needed? If yes, can you please share?
EDIT: it seems it is GitHub - aristocratos/bpytop: Linux/OSX/FreeBSD resource monitor
Is this available through as a CE addon?
add it manually
Any chance of adding the Player Process info Button to the OSD?
Like in CoreELEC NG,NE
Can still access, just have been spoiled with that option in others.
Also noted in
Settings
System
System information
Video
Display supported HDR types:Dolby Vision up to 4k60Hz
This is new/can read/get data from EDID?
Did not see this in other builds?
Is a feature if NO only?
I like it !!
  1. It’s there, just moved by Kodi video osd, to settings, player info
  2. It’s NO only yes. Old TV or most AVR may support DV only up to 4k24p
1 . In NG,NE you added button to default Estuary Skin.
When pause playback is what iam referrering to
When I press OK/enter its at the bottom of the screen in the gear wheel.
I have also mapped a button on remote to show same using Kodi Keymap editor addon.
Yes Thanks
I know its there
My memory is fading,maybe is different skin iam thinking about with NG NE
Here is screen shot from CoreELEC. NE lastest Nightly.
Looks like Kodi 22 has moved it to Settings
Yes, I removed the icon from the NO in the CE Estuary , when I made the pull request , because of kodi 22 changes.
The CE team agreed and merged.
Is it the O key information that you are looking for? It is still working here. If so maybe your keymap needs to be updated.
No
That function on keyboard letter " o " still works
Frodo 19 explained
All is good
Thx for reply
I discovered something, after restoring a backup from ce21.2 to CE 22 NO, the file transfer was 11mbps only from Windows to CE, and it kept getting stuck when playing movies, so I decided to put the dtb.img back in the folder, which solved this problem. Now it’s back to 110mbps transfer on Windows and it stopped getting stuck on movies.
I tested it on 2 different sdcards. Same result, only after replacing the dtb.img again it returned to normal.
You will need to share your different two dtbs to compare.
I have got NO working ok on my Tox3 now… :slight_smile:
I am using the sc2 4gb 1gb.
I have also found with NO on my tox3 it is always slow on 1st boot.
When I reboot from SD card it comes good. I don’t turn off until next update when I repeat the reboot after setup.
Mine only has ethernet too, no wifi. BUT happy to continue with NO :wink:
I think I have a few not approved addons so cant put up a log atm.
Later I will when I check the list…
Hmm, that could be the problem then, mine is also tox3, so changing the DTB was just a placebo lol because they were the same size.
Today I was surfing the live tv channels and noticed that some channels were not working.
These channels work on CE new order releases with kernel build 5.15.119 and kernel build 5.15.137, but not on kernel build 5.15.153.
Other channels with the same tp are working.
Info bar pictures of the non-working channel.
dmesg 5.15.119
https://paste.coreelec.org/InterpolDumpster
dmesg 5.15.137
https://paste.coreelec.org/PotionDramas
dmesg 5.15.153
https://paste.coreelec.org/DryingFrame
I don’t know if there will be any information in the log, but just now I turned on the tox3 and it was slow again, I tried to restart it twice and it was still slow and loading during the movies, it was probably limited to 11mbps again, so I had to unplug it and turn it on again and it went back to normal.
log-2025-04-25-12.03.03.zip (388.2 KB)
samples would be easier and faster for testing.
The “stutter” after suspend should be fixed with tomorrow nightly.
The CPU wasn’t running with full power after resume. Some workaround do fix this issue.
Like the Minix U8K is right be back up online after switch on the TV. So power on TV and resume take about 3-5s now.
Record the channel and then the recording can be watched.
StĂźdyo BrĂźksel-EKOTURK HD2025-04-2517-00-1.ts (8.8 MB)
I can turn on Terminal Sharing.
Phone recording and device channel recording.
Phone recording
https://s6.dosya.tc/server22/b7n7j7/20250425_172648.mp4.html
Device recording
https://s6.dosya.tc/server22/u7isqk/Studyo_Bruksel-EKOTURK_HD2025-04-2517-00.rar.html
