That is a nice box, in deed. But this kid was all in to Vero 4k+, and I told him not to bother. I have been selling CE on him know and would like to deliver that.
Youâll always get what you pay for. You have the VIM3L with CoreELEC that has a nice price tag and is a wonderful device. Here we tend to prefer SBCâs. In the other devices you have the GT king that is fully supported by CoreELEC. On the cheap end of things people seem to be appreciating the X96 air but like the other devices in that family you can run into a box with a different WiFi/BT chip.
So, you can run CoreELEC perfectly well in a huge variety of devices.
Is 9.2.1 working properly on Mecool KM9 905X2 Box?
Because on Kodi i have small microstuttering on fast moving scenes and want try this if can fix that.
Anyone that works with the dtb images, it should be.
I have giving dmesg logs of USB activity under both Android 9 that has the two functional USB ports, and CoreELEC that only one functional USB port, the USBv3 thatâs a host. Available at Beelink GT1 Mini & CoreELEC, No USBv2 Port
USB-OTA (USBv2) port on this GT1 Mini needs to also act as a host too, or do dual-roles and Itâs not. From my research, Itâs all controlled via dtb image file.
So GT1 Mini users and alike shares such a problem, you canât use USB-OTG port to install CoreELEC. You have to use another port, and in my case GT1 Mini only has one other USB port and we need to be able to use Keyboard to configure CoreELEC and also operate Kodi. Need to use an USB Hub, also once CoreELEC is installed via USB, the USB-OTG port still remains unusable⊠Using USB over SD Card does nothing to address the non-functional USB-OTG port under CoreELEC.
@Phant0m
Is this the box you have from G-Worst ?
Picture shows 2 USB Ports in picture but no mention in specs for the second one.
That is the box I own, but not the box we discussing. Itâs GT1 Mini, the original one.
The one I have has 4GB of RAM, 64GB Storage⊠https://www.awaqa.com/beelink-gt1-mini-review-tv-box-price-buy/
Figured it out yesterday⊠thanks @TheCoolest - Beelink GT1 Mini & CoreELEC, No USBv2 Port
The issue with GT1 Mini is the USBv3 port isnât the blue colour-coded port for quick identification, thatâs next to the Micro-SD / TF reader. Itâs actually the black colour-coded port thatâs actually the USB-v3 port.
There need to be a specific DTB for GT1 Mini, because the parameters used for calling needs to be reversed.
What remote config use for Mecool KM9 Remote with control, after enter ssh command my remote have delay and alos cant power on device with him.
Hi!
Iâve got VONTAR KIII Android 5.1.1 TV Box 2GB/16GB K3 Amlogic S905 2.4/5G Dual Wifi 1000M Gigabit LAN BT4.0 UHD 4K 3D KODI with CoreELEC 9.2.1 there.
WiFi soft AP is not working.
$ iw dev
phy#0
Interface wlan0
ifindex 3
wdev 0x1
addr ff:ff:ff:ff:ff:ff
type managed
Could you please provide any pointer to why wlan0 is assigned an invalid MAC (ff:*) â my boot logâs here http://ix.io/27Pk
TIA
I have the same issueïŒ but I donât know what to operate. from SSH enter or just operate it on KODI?
from a windows pc, use putty, login root password coreelec (these are default values)
OlĂĄ Pessoal,estou com uma Gamebox G11 PRO,S905x2 e 2gb de ram,porem a rom estĂĄ corrompida,na placa o nome estĂĄ como GAMEBOX_eMCP V1.2,nem o reset de fabrica faz abrir o android,alguem sabe qual a firmware desta game box?
This an English forum only, is it too much to ask you to use google translate
OlĂĄ, este forum Ă© em inglĂȘs apenas, serĂĄ pedir muito que use o tradutor do Google? Muito obrigado.
