I used another USB to Ethernet adapter (Microsoft Surface Ethernet adapter) and this one is working flawlessly. Please note that it has another hardware ID which leads me to this that it is a driver issue.
[ 175.930965@2] usb 2-1.4: new SuperSpeed USB device number 5 using xhci-hcd
[ 175.951599@2] usb 2-1.4: New USB device found, idVendor=0bda, idProduct=8153
[ 175.951607@2] usb 2-1.4: New USB device strings: Mfr=1, Product=2, SerialNumber=6
[ 175.951609@2] usb 2-1.4: Product: USB 10/100/1000 LAN
[ 175.951612@2] usb 2-1.4: Manufacturer: Realtek
[ 175.951614@2] usb 2-1.4: SerialNumber: 001000001
[ 175.967935@2] usb 2-1.4: Unsupported device
[ 175.968084@2] usb 2-1.4: Unsupported device
[ 176.095409@2] usb 2-1.4: reset SuperSpeed USB device number 5 using xhci-hcd
[ 176.127697@2] r8152 2-1.4:1.0 (unnamed net_device) (uninitialized): Unknown version 0x6010
[ 176.127705@2] r8152 2-1.4:1.0 (unnamed net_device) (uninitialized): Unknown Device
[ 176.127753@2] usb 2-1.4: Unsupported device
According this ubuntu bug discussion, a driver update is required to make the device work and this is the driver patch. I am unfortunately not familiar with CE build process to apply it.
Perfect. I have one of those too, although mine is a 8153. But it refuses to work in USB 3.0 mode, not sure why.
[ 1070.950127@3] usb 2-1.2: New USB device found, idVendor=0bda, idProduct=8153
[ 1070.950130@3] usb 2-1.2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 1070.950132@3] usb 2-1.2: Product: USB 10/100/1000 LAN
[ 1070.950134@3] usb 2-1.2: Manufacturer: Realtek
[ 1070.950135@3] usb 2-1.2: SerialNumber: 00xxxxxxxxxx
[ 1070.960589@3] usb 2-1.2: Unsupported device
[ 1070.962007@3] usb 2-1.2: Unsupported device
[ 1071.070526@3] usb 2-1.2: reset SuperSpeed USB device number 5 using xhci-hcd
[ 1071.158669@3] r8152 2-1.2:1.0 eth1: v1.08.9
[ 1071.191489@4] IPv6: ADDRCONF(NETDEV_UP): eth1: link is not ready
[ 1073.262484@3] r8152 2-1.2:1.0 eth1: Stop submitting intr, status -71
[ 1073.263159@3] usb 2-1.2: usb_reset_and_verify_device Failed to disable LTM
[ 1073.263159@3] .
[ 1073.789566@3] usb 1-1.2: new high-speed USB device number 5 using xhci-hcd
[ 1073.890136@3] usb 1-1.2: New USB device found, idVendor=0bda, idProduct=8153
[ 1073.890139@3] usb 1-1.2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 1073.890141@3] usb 1-1.2: Product: USB 10/100/1000 LAN
[ 1073.890142@3] usb 1-1.2: Manufacturer: Realtek
[ 1073.890144@3] usb 1-1.2: SerialNumber: 00xxxxxxxxxx
[ 1073.918676@3] usb 1-1.2: Unsupported device
[ 1073.918746@3] usb 1-1.2: Unsupported device
[ 1074.011337@3] usb 2-1.2: USB disconnect, device number 5
[ 1074.078491@3] usb 1-1.2: reset high-speed USB device number 5 using xhci-hcd
[ 1074.262373@3] r8152 1-1.2:1.0 eth1: v1.08.9
[ 1074.295488@4] IPv6: ADDRCONF(NETDEV_UP): eth1: link is not ready
I had one of those in the same form of my current one (3 x USB 3.0 ports + 1 GBe Ethernet port). The Hub is USB 3.0 however the Ethernet card only work at 300 to 350 mbits which lead me to think that either the Ethernet chip is only connected to the hub through a USB 2.0 link or that the there is something faulty in the firmware of the hub itself.
I have an issue playing the Jellyfish (http://jell.yfish.us/) samples on my KM9 Pro. I tried with the 400 Mbits HVEC file (I am running an SSD as the boot and storage drive so no IO bottleneck). On Android the file plays very smoothly. However in CE, the hole UI starts to blink (lines, artefacts, etc, ). Is there any issue with the hardware decoder in CE ???
First of all Iâm noob and i want to thank everyone out there for contributing on this wonderfull endless open project. a big applause from me (and probably from many many others)
for helping people and make there life easier, hats of and salute all for the big efforts and many hours.
Here it comesâŚ
it seems to me that multiple hardware and âmain softwareâ (like kodi,linux etc.) providers are in a transition phase to newer and better products, and noticing that you people are working very hard to keep up with all this on many frontsâŚ
I started thinking about postponing my new hardware purchase untill the very first âofficiallyâ stable S905X2 version is released. (initially i was thinking about getting a [H96 MAX X2] one of these days) Should I get this hardware a.s.a.p.? or should i wait till the stable version is released? or should I skip on this hardware and wait for the S905X3?
Can someone make an educated guess about, how long it can take untill S905X2 (bugless) stable version is released?
I think itâs the USB device, not hub, because I get about the same speed when I connect it to the PC.
Itâs probably a USB 3.0 device, but doesnât have the right connections for USB3.0 to actually work.
Regarding the Jellyfish playback. Weâll need Kodi and dmesg logs. In Kodi enable video component debugging first.
Then reboot and run the video. After that collect and post the logs.
The adapter is limited to USB 2.0 speed on my computer as well, so itâs not the box.
And a USB 3.0 SD card reader works fine and gets close to 80MB/s reads.
Then I suggest get another adapter (like the Hub one). It is really fast and gives you 3 additional USB 3.0 ports. My SSD is actuallu plugged into one of those ports and the box is able to use it as a boot device.
To all users what where applying the bl301 bootloader blob injection:
Please make again with the last nightly (0814) again a injection by running the tool inject_bl301 to enable auto update of the bl301 blob.
Thanks for the hard work that is being done.
I donât know if this is the right thread, if not I am sorry.
I now have a x96 max s905x2, but I can not get the right aspect ratio with 1080p hevc files that are 1920808 pixels. I tested the same file in x264 and then it displays the correct aspect ratio.
With 1080p hevc 1920808 pixels 24hz display, when I choose original aspect ratio in video settings it is more like a square, if I choose normal itâs stretched to a 16:9 aspect ratio with no black bars. If I then apply a pixel ratio of 1.30 the aspect ratio is correct, but the right and left sides have something weird going on like a fish eye effect, and it is distracting while watching.
Can anybody confirm this problem? 1080p hevc 1920*1080 pixels watches fine in the correct aspect ratio
I would still like to add I now tried to play 1080p hevc 1920x816 pixels if i just boot up the x96 max s905x2 in android mode. In the VLC media player I also canât get the correct aspect ratio. Best Fit is just stretched out 16:9. Original aspect ratio is a square. So in VLC it is even impossible to get the correct aspect ratio. It has the exact same problems as the coreelec system. So what does that say? is it a s905x2 problem. All I know is that the chromecast ultra displays the correct wide screen aspect ratio right away, and doesnât give the fish eye effect on the left and right sides. Greetings
