I haven’t used my ODroid-N2+ to watch live HDTV for a while but with the Euros on, it’s getting a lot of use! I notice that there are a lot of blocking artifacts on the screen during playback, both when playing a recording and watching live. After some of my own debugging these are the facts:
- Both my media server and ODroid-N2+ are connected via gigabit Ethernet.
- The artifacts do NOT appear on the recordings themselves (they play fine on my PC).
- The artifacts DO appear at the same time and place on the video every time (e.g. I see artifacts, then rewind and see exactly the same artifacts again in the same place).
- The artifacts do NOT appear when I disable hardware acceleration (but playback is choppy so this is not a solution).
- The artifacts DO appear in both CoreElec 20 and 21.
So I know it’s not a streaming/network issue and it’s not a continuity error issue with the streams themselves. It must be either dying hardware or a hardware decoding or driver bug on the ODroid-N2+.
Does anyone else have this issue? I’ve attached both debug logs from when I was playing a section of video that artifacts and the sample video (the whole graphic at the bottom artifacts when the on-screen match timer shows 41:06), which is standard UK HDTV: AVC Main@L4, CABAC, 4 ref frames.
