I’ve been using an old WiFi N module but just bought the USB-AC51 for AC Wifi support. However when I connect it and go to Connections nothing shows up, only when I plug in the old adapter do I get the networks showing up.
Based on an older thread the chipset is compatible: CoreELEC 8.99.1.1 breaks wifi with MT7610U
Any ideas on how to get it working? Reboot didn’t help. I’m using the Odroid N2.
Lounge:~ # cat /etc/os-release
NAME=“CoreELEC”
VERSION=“9.2.1”
ID=“coreelec”
VERSION_ID=“9.2”
PRETTY_NAME=“CoreELEC (official): 9.2.1”
BUILD_ID=“30fb1ed4f1ad03b2ff52d69ca300be30964f2637”
OPENELEC_ARCH=“Amlogic-ng.arm”
LIBREELEC_ARCH=“Amlogic-ng.arm”
COREELEC_ARCH=“Amlogic-ng.arm”
COREELEC_BUILD=“official”
COREELEC_PROJECT=“Amlogic-ng”
Lounge:~ # lsusb
Bus 002 Device 002: ID 05e3:0620 Genesys Logic, Inc.
Bus 001 Device 007: ID 0bda:8178 Realtek Semiconductor Corp. RTL8192CU 802.11n W LAN Adapter
Bus 001 Device 006: ID 0b05:17d1 ASUSTek Computer, Inc. AC51 802.11a/b/g/n/ac Wi reless Adapter [Mediatek MT7610U]
Bus 001 Device 004: ID 24ae:2000
Bus 001 Device 003: ID 0a12:0001 Cambridge Silicon Radio, Ltd Bluetooth Dongle ( HCI mode)
Bus 001 Device 002: ID 05e3:0610 Genesys Logic, Inc. 4-port hub
