I checked the URL on virustotal, the checksum matched what they had on file from 2 years ago VirusTotal so I suspect a false positive.
I downloaded this file https://github.com/CCExtractor/ccextractor/releases/download/v0.88/ccextractor-0.88_no_windows.zip and upload it to VirusTotal and it has 2 positive results. If they are real or not I donāt know
I use virustotal for some software I write and there are almost always false positives on a few of the lesser known scanners. The file you checked was the Linux version, so with all the scripts etc,it is bound to fail.
I donāt know exactly but I would not be surprised that the developer has a virus on his computer ā¦ that would explain why several Bulds have serious bugs and defective
I donāt know but I can say that CW detected BTC miner in many VPNā¦ when I contact them they offer me a free timeā¦
In my opinion this build have virus trojan for sure Clamwin is the most efficient anti virus in the world is slow but ruthless
Interesting the same sha256 as I used for the URL
5823d0bd9cf872e2fc99f93219ef7daa89ddeae7154a25420c7022311de30a77 gives a different response. I still suspect a false positive.
@vpeter has this URL VirusTotal but one a/v is reporting an avcodec scan.
Probably the fact that it is a shell to another exe is what makes it seem suspicious.
0.90 work good very fast and no virus ā¦ but no portable build nor drag and drop
Finaly I report the KODI issue here Kodi does not see and does not play Bad Hearing subtitle / Teletext CC608 Ā· Issue #23038 Ā· xbmc/xbmc Ā· GitHub
