Hi i just got the new Beelink GT-King Pro and i would like to ask a couple of questions.
- Is the GT-King Coreelec image compatible with the Pro version?
- I don’t care about android, i would rather installtointernal. Is there a guide for this?
Thank you i tried the SD card method and it works but it is very slow. Maybe my Sd card is not fast enough? I would still prefer to install to internal memory but somehow i can’t find any step to step guides for it.
Probably because it does not exist…
Btw, which part of “There is no installtointernal” you don’t understand ?
I changed SD card. The one i originally used was obviously not fast enough. Luckily i had a newer and faster available and it works very well now.
You don’t need an SDCard, it is also possible to use a USB Key (of course you sacrifice a usb port).
Please refer to my above post re: ceemmc
One question, does this not support s905x2? Since it detects the s905x2 dtb and says it is not supported.
yes, with s905x2 dont working too.
ceemmc isn’t supported on the beelink gt-king rev-a.
Apologies I didn’t realise it had not been expanded to other devices yet.
which DTB should I use for the Pro (S922X-H) version? Mine seems to boot only with the Rev A DTB and therefore is limited to 1.7 GHz. Is this expected? Serial starts with 290a4000.
Thank you.
