Do you own a vontar x4? first I heard of it. I normally think of tox3 as a box to recommend for the best value but the vontar is a nice bit cheaper
@ confused
yup had it for well over a year nowā¦just realised earlier this week when I was trying to figure out docker that I was booting off an SD card lolā¦wrote to emmc and it fliesā¦
Iām not Michael Saylor so I donāt have an 85" 8k TV or feel the need for āDolby Digital fake sound 2025ā
perfect confused, most donāt care for DV or have external speakers so the Vontar x4 will be more than enough for most needs, thanks for sharing, Iād recommend that box in the future
Is there a difference in image quality in CoreElec between the S905X2, S905X3, S905X4, S922x, and S928X processors (without considering DV)?
Iām asking this because I felt like I had better image quality, especially better colors, when playing my videos with Android apps on a TV box with an S922X (and even some Realtek SoCs), rather than an S905X2 or X3.
But is it the same on CoreElec? Or does the SoC have no impact on image quality and colors?
The SOC should not affect the image quality at all. Most of them have identical hardware decoders for a codec. Think of a SOC as a lego set. Itās built from many different parts that are snapped together. The hardware decoder for a specific codec is usually the same across sets.
Netflix are more adding hdr10+ with av1 encoding to their videos.
Wood coreelec support this?
@Sholander @frodo19
I got the Ugoos Am6b+ todayā¦
installed Corelecā¦
no library updates ⦠wanted to see if it could play Lotr Remux DV (profile 7)ā¦
Dolby vision Light on TVā¦
as i ve said⦠i have a huge library⦠and was very sceptical on the browsing speedā¦
added some of my directoriesā¦
the browsing speed is really amazingā¦
So far i have to say this
THANK YOU FOR MAKING ME BUY THE UGOOS ITS AN AMAZING BOXā¦
WILL BUY ANOTHER FOR MY 2nd TVā¦
(just have to figure out how to make it save library on external usb - 32gb internal storage not much for me
PS: Remote is really CRAP⦠but it the device supports CEC (so i can use LG remote)
(i also paired it with a bluetooth keyboard and everything now is super cool) ![]()
something is up with AliExpress, since the tariffs Iām not getting an extra charge for VAT. Iām shipping it to UK.
anything I buy says VAT included in the price.
You are basically getting 17% discount and itās giving me way more discount for coins, anyone else get the same?
Probably Ali finally made the deal with UK to include VAT in their prices, same as is with EU. I always get āVAT included in the priceā when buying from them.
Can you or somebody exactly explain why i only can fully replace a disc based player with Ugoos AM6b+ and not the Dune Homeatics Box R 4k Plus?
Where did you get that wrong info? Both boxes can fully replace UHD-DV Disk player, since they both reproduce full FEL. Get full/correct info here
The S904X4 does not have the power to decode all media formats found on blu-ray discs (24fps VC1, Mpeg2, and 3D is currently broken).
Noticed this poll in several forums: Kodi, AVS, etc. Interesting results so far. Top choice not surprising, but looks like people still like Shield TV & Fire Cube.
Interesting reason for such resultsā¦
I am looking for an inexpensive hardware with S905Y4, where Coreelec can be easily installed and operated.
At the moment there are two devices under 60 euros on Amazon:
https://www.amazon.de/Android-Certified-Quad-Core-Assistant-Bluetooth-WeiĆe/dp/B0D7C7JDXQ
and
https://www.amazon.de/RUPA-HOMATICS-11-Android-Box-2G-16G/dp/B0BG58R1LF
Does anyone already have experience with this?
I am asking this question because I have already ordered a hardware once for which the installation of Coreelec was not possibleā¦
I donāt believe that on any of those CE can be installed, because they are both Widevine L1/Netflix certified. On such protected boxes usually CE cannot be installedā¦
If You want the best for Your money
They can probably both be used with CE. One is from Homatics, the other is being used with CE by this user
Why you recommend this, over the others?
No Operating System
No eMMc ,just an empty socketā¦
I suppose boot CoreELEC from SD Card slotā¦
4 gig DDR4 is good!!
