Which is the best Android Box for CoreElec?
I would like to use for torrent, and watch movie.
I bought a X96 Max Plus 4/32 but it cannot run CE on it.
I had exactly the same problem like this one , and they did not found solution,
So I want to buy an Android Box from uk amazon, or uk ebay which can run CE without problem.
Which one would you recomend it?
I’m running CE on a X96 Max + with no problems. The recommended device would probably be the N2 +
cannot buy uk amazon or uk ebay
I would like to buy from those 2 site.
I understand you do not have problem, but I got same what is in that link
how should I know which one is working, which one not?
If you are wanting a box from Amazon I can recommend a Khadas VIM3L HTPC kit. You will need a USB power adaptor to power it since it is not part of the kit. This is a 2GB S905D3 box. Alternatively if you want something more powerful you can build your own VIM3 from the various components listed on Amazon.
I use both boxes and they come with internal storage and WiFi & Bluetooth included as standard.
So you want to use it with a torrent to watch movies illegally.
Not a good start being so open about your proposed criminality.
if you thinking this way, that is meaning you do it too.
I am far from my home, and the only way to watch my land series, or anything on my language is torrent.
Think big
Take your advice on another forum.
This is not the right platform for your intended use.
