No issue with black screen here
S912 Pioneer Avr Sony HDR TV
Issue I have is box boots at 1080p 4:4:4 30 bit
Then UHD content plays at 4:4:4 2160p 30 bit
Rx Brand Name: PHL
Rx Product Name: Philips
Manufacture Week: 10
Manufacture Year: 2015
Physical size(cm): 128 x 72
EDID Version: 1.3
EDID block number: 0x1
blk0 chksum: 0x70
Source Physical Address[a.b.c.d]: 3.0.0.0
YCC support 0x03, VIC (native 255):
ColorDeepSupport 0x38 10/12/16/Y444 1/1/0/1
16 31 32 34 33 5 20 4 19 18 3 17 2 22 7 21 6 1 93 95 94 95 94 93 353 352
Audio {format, channel, freq, cce}
{1, 1, 0x1f, 0x07}
{2, 5, 0x07, 0x00}
{7, 5, 0x07, 0x00}
Speaker Allocation: 0x01
Vendor: 0xc03
MaxTMDSClock1 300 MHz
SCDC: 0
RR_Cap: 0
LTE_340M_Scramble: 0
DeepColor
checkvalue: 0x70d60000
Kodi was set to 4K Resolution.
So, i hope it will be helpfull.
@mhbosch Does your TV support HDR?
No, i think the TV doesnt support HDR.
Same problem here with black screen on 8.95.4.1 everything was fine on 8.95
4 using:
H96 PRO+ Plus 3/32 (S912) + 4K TV with HDR. Kodi was set to 4k resolution
I downgraded it to 8.95.4 and everything is working now.
If you want me to replicate the black screen again and need some log just let me know what do you need then I’ll send you.
UPD: this is cat for edid file in a working build 8.95.4
# cat /sys/devices/virtual/amhdmitx/amhdmitx0/edid
Rx Brand Name: HEC
Rx Product Name: HISENSE
Manufacture Week: 12
Manufacture Year: 2016
Physical size(cm): 115 x 65
EDID Version: 1.3
blk0 chksum: 0x7f
Source Physical Address[a.b.c.d]: 4.0.0.0
95 94 93 1 2 4 5 16 17 19 20 31 32 33 34 98 99 100 95 94 93 98 352 353 362 363
{1, 1, 0x07, 0x07}
{2, 5, 0x07, 0x00}
{10, 5, 0x06, 0x00}
Vendor: 0xc03
ColorMetry: 0xff
SCDC: 0
RR_Cap: 0
HDR DeepColor
checkvalue: 0x7fa50000
1080p, no avr.
KIII + LG C7 witout AVR = black screen:
Rx Brand Name: GSM
Rx Product Name: LG
Manufacture Week: 1
Manufacture Year: 2017
Physical size(cm): 160 x 90
EDID Version: 1.3
blk0 chksum: 0x63
ColorDeepSupport 0xb8 10/12/16/Y444 1/1/0/1
93 16 31 4 19 5 20 3 2 18 32 33 34 21 1 94 95 98 99 100 63 64 95 94 93 98 352 353 357 358
{1, 1, 0x57, 0x07}
{2, 5, 0x07, 0x00}
{10, 7, 0x07, 0x01}
{7, 5, 0x06, 0x00}
{12, 7, 0x04, 0x03}
Speaker Allocation: 0x00
Vendor: 0xc03
ColorMetry: 0xc0
SCDC: 0
RR_Cap: 0
DolbyVision1 HDR DeepColor
checkvalue: 0x636b0000
Black screen on 8.95.4.1. K1Pro with LG 4K TV
Rx Brand Name: GSM
Rx Product Name: LG
Manufacture Week: 1
Physcial size(cm): 160 x 90
EDID Verison: 1.3
blk0 chksum: 0xa0
Source Physical Address[a.b.c.d]: 1.0.0.0
native Mode f1, VIC (native 31):
ColorDeepSupport b8
16 31 4 19 5 20 3 2 18 32 33 34 21 1 96 97 93 94 95 101 102 98 99 100 95 94 93 98 352 353 357 358
{7, 5, 6, 0}
{2, 5, 7, 0}
{1, 1, 57, 7}
Vendor: 0xc03
Vendor2: 0xd85dc4
MaxTMDSClock2 600 MHz
ColorMetry: 0xc0
SCDC: 1
RR_Cap: 0
DeepColor
checkvalue: 0xa09e0000
Hi Inter95
Do you have some link for download Version 8.95.4.tar for ARM-S912?
THX and greetings
RAD
At the 8.95.4 i have NO problems. What now?
Bqeel m9c max S905X 2GB RAM, coreelec on NAND, no log because its brick/not work
TV JTC Genesis 55z UHD 2160p
24 posts were split to a new topic: Green screen 8.95.4.1
Since the auto update to this version I have a black screen. I have a Denon XR2100W that the signal is sent through to my Samsung 50 (don’t remember model).
A few extra questions to help figure this out.
do the people having this problem have any settings in a /storage/.config/autostart.sh file?
also what is the contents of /sys/devices/virtual/amhdmitx/amhdmitx0/config
and contents of /sys/devices/virtual/amhdmitx/amhdmitx0/disp_cap
and /storage/.kodi/userdata/disp_cap
I’m on windows 10. I don’t see the device on the network (haven’t looked before). Do I need putty? Has it booted but just isn’t rendering. I’ll try and get my info if I can connect.
yes it has booted, but is not displaying an image. and putty would be required to connect over ssh.
to ssh into the device you need to know it’s ip address, or corelec.local might also work as an address to connect to. if you didn’t change the hostname when you set the device up.
login: root
password: coreelec
(password might be libreelec if you have upgraded to coreelec from libreelec at some point in the past without doing a fresh install)
then once you have a command prompt, type
cat /storage/.config/autostart.sh
cat /sys/devices/virtual/amhdmitx/amhdmitx0/config
cat /sys/devices/virtual/amhdmitx/amhdmitx0/disp_cap
cat /storage/.kodi/userdata/disp_cap
will show the contents of those 4 files. then just cut and paste the results from the putty window and post here.
Only
echo off > /sys/class/leds/librecomputer:system-status/trigger
echo off > /sys/class/leds/librecomputer:blue/trigger
CoreELEC:~ # cat /sys/devices/virtual/amhdmitx/amhdmitx0/config
cur_VIC: 353
VIC: 353 3840x2160p60hz
Colour depth: 10-bit
Colourspace: YUV420
Colour range: limited
EOTF: SDR
YCC colour range: limited
PLL clock: 0xc000029a, Vid clock div 0x000b0000
audio config: on
3D config: off
CoreELEC:~ # cat /sys/devices/virtual/amhdmitx/amhdmitx0/disp_cap
480p60hz
576p50hz
720p60hz
1080i60hz
1080p60hz
720p50hz
1080i50hz
1080p30hz
1080p50hz
1080p25hz
1080p24hz
2160p30hz
2160p25hz
2160p24hz
2160p50hz420
2160p60hz420
CoreELEC:~ # cat /storage/.kodi/userdata/disp_cap
cat: can't open '/storage/.kodi/userdata/disp_cap': No such file or directory
Also I noticed when I downgrade so I can use kodi again (not sure if its supposed to be shorter):
CoreELEC (official): 8.95.3 (LePotato.arm)
cur_VIC: 353
cur_video_param->VIC=353
cd = 4
cs = 3
audio config: on
3D config: off
Hi All,
Sorry for asking again.
Could someone please post the link for download ver. 8.95.4.tar for S912 ?
Big thx
RAD
CoreELEC (official): 8.95.4.1 (S905.arm)
TVroom:~ # cat /storage/.config/autostart.sh
cat: can’t open ‘/storage/.config/autostart.sh’: No such file or directory
TVroom:~ # cat /sys/devices/virtual/amhdmitx/amhdmitx0/config
cur_VIC: 353
Colourspace: YUV420
EOTF: SDR
audio config: on
3D config: off
TVroom:~ # cat /sys/devices/virtual/amhdmitx/amhdmitx0/disp_cap
480p60hz
576p50hz
720p60hz
1080i60hz
1080p60hz
720p50hz
1080i50hz
1080p30hz
1080p50hz
1080p25hz
1080p24hz
2160p30hz
2160p25hz
2160p24hz
smpte24hz
smpte25hz
smpte30hz
smpte50hz420
smpte60hz420
2160p50hz420
2160p60hz420
TVroom:~ # cat /storage/.kodi/userdata/disp_cap
cat: can’t open ‘/storage/.kodi/userdata/disp_cap’: No such file or directory
TVroom:~ # ##############################################
TVroom:~ # # CoreELEC #
Colourspace: YUV420
EOTF: SDR
audio config: on
3D config: off
480p60hz
576p50hz
720p60hz
1080i60hz
1080p60hz
720p50hz
1080i50hz
1080p30hz
1080p50hz
1080p25hz
1080p24hz
2160p30hz
2160p25hz
2160p24hz
smpte24hz
smpte25hz
smpte30hz
smpte50hz420
smpte60hz420
2160p50hz420
2160p60hz420
TVroom:~ #
TVroom:~ # # https://coreelec.org #
TVroom:~ #
TVroom:~ # CoreELEC (official): 8.95.4.1 (S905.arm)
-sh: syntax error: unexpected word (expecting “)”)
-sh: syntax error: unexpected “)”
TVroom:~ # TVroom:~ # cat /storage/.config/autostart.sh
-sh: TVroom:~: not found
TVroom:~ # cat: can’t open ‘/storage/.config/autostart.sh’: No such file or dire
ctory
cur_VIC: 353
Colourspace: YUV420
EOTF: SDR
audio config: on
3D config: off
480p60hz
576p50hz
720p60hz
1080i60hz
1080p60hz
720p50hz
1080i50hz
1080p30hz
1080p50hz
1080p25hz
1080p24hz
2160p30hz
2160p25hz
2160p24hz
smpte24hz
smpte25hz
smpte30hz
smpte50hz420
smpte60hz420
2160p50hz420
2160p60hz420
-sh: cat:: not found
TVroom:~ #
@RAD I don’t have a copy of 8.95.4 for the S912, it’s possible another dev does.
I do have a test image for the s912 that you could try, that might fix the black screen for you.
if you are interested/
