Black Screen with 8.95.4.1 and 4k TVs
So it seems that in fixing the previous black screen problem we have introduced a new black screen problem for users with 4k TVs.
Like the blackscreen issue on 8.95.4 this is an issue with the information provided by the TV to your device, and how CE uses that information. So when CE receives incorrect information about your TVs capabilities, it gets confused and thinks the display mode requested by kodi is not possible, even when it is. Resulting in a black screen/no signal.
As stated before the shear number of different models of TVs, combined with the number of different AVR that could be used with them makes this impossible to test on every possible combination before release.
If users affected by this can post the make and model of TV, and if the TV has HDR support, and state if you have an avr between your device and the TV
also the contents of
/sys/devices/virtual/amhdmitx/amhdmitx0/edid
would be helpful.
also if you using an AVR or other device between your device and the TV, try directly connecting your device to the tv, and providing the out put of the previously mentioned file while directly connected to the TV.
edit: and if you haven’t already posted one a kodi log, and the output of dmesg might be helpful as well. (though remember to use pastebin or similar method for the log file and dmesg output since they can be pretty big and make the thread hard to follow when pasted directly into a message. )
Just updated my S912 to 8.95.4.1 and now I don’t see anything after booting. When I ssh to my box I see that Kodi is running. Tried the disp_cap part but it didnt work.
EDIT: Forgot the log
I still have the black screen with 8.95.4.1 on my Mini MXIII II (s905x).
Here are the logs:
kodi: http://ix.io/1q4K
dmesg: http://ix.io/1q4L
When I start kodi normally (reboot) I can see the splash and then my TV says there is no signal. If I create the disp_cap file the behavior is slightly different. I still get to see the splash, then the TV is black but it seems to get a signal.
i have between Odroid C2 an TV a Denon AV Receiver. When i connect directly the Philips 4K Android TV, i have a Screen. When i go down in Resolution on Full HD, the AV Receiver show the screen. After a select in Kodi to 4K, the AV Receiver show a black screen…
So, i think, the new Version have a Problem with 4K Resolution on certain Devices. Before the upate, the AV Receiver show 4k Resolution.
I hope, it was helpfull. btw, the disp_cap hint have doesnt help me.
Thank you for trying this, I too have a Denon AVR and can confirm this behavior. Setting the Display resolution in kodi to 1080p instead of 4K fixes the black screen for me.
This is still a bug though and will hopefully get fixed in the next version
Do you know, can i make a downgrade?
Beelink Gt1 (not ultimate). Updated to 8.95.4.1 from 8.95.3 and black screen issue appeared. Using a Yamaha AVR(RX-V483) between the Beelink and the tv(Samsung UE65MU7002). Had no issues when using 8.95.3. Already have reverted, and waiting an update.
8.95.4 working fine via KIII
but after upgrade to 8.95.4.1 i have black screen after logo coreelec
how fix it ?
Just upgraded my KIII to 8.95.4.1 and I don’t have this issue. (8.95.4 was also working fine)
@derTyp @jtsarnas @mhbosch can you please post the contents of
@mhbosch yes its possible to downgrade to 8.95.3 by placing the appropriate .tar file for your build into the .update folder on your device. so in your case for the C2 that would be CoreELEC-Odroid_C2.arm-8.95.3.tar
Same issue on le potato. 8.95.4 was fine, 8.95.4.1 only black screen after boot logo.
cat /sys/devices/virtual/amhdmitx/amhdmitx0/edid
Rx Brand Name:
Rx Product Name:
Manufacture Week: 0
Manufacture Year: 1990
Physical size(cm): 0 x 0
EDID Version: 0.0
EDID block number: 0x0
blk0 chksum: 0x00
Source Physical Address[a.b.c.d]: 0.0.0.0
YCC support 0x00, VIC (native 0):
ColorDeepSupport 0x00 10/12/16/Y444 0/0/0/0
Audio {format, channel, freq, cce}
Speaker Allocation: 0x00
Vendor: 0xc03
MaxTMDSClock1 0 MHz
SCDC: 0
RR_Cap: 0
LTE_340M_Scramble: 0
checkvalue: 0xb7de0000
@Kiina can you tell me which tv you have and if you have an avr between the le potato and the tv?
PHILIPS 55PUK4900. I have a Yamaha RX-v381 in between but I tested a direct connection just now and same behaviour
can you give me the output of that last file when directly connected?
Rx Brand Name: PHL
Rx Product Name: Philips
Manufacture Week: 32
Manufacture Year: 2015
Physical size(cm): 128 x 72
EDID Version: 1.3
EDID block number: 0x1
blk0 chksum: 0xa4
Source Physical Address[a.b.c.d]: 2.0.0.0
YCC support 0x03, VIC (native 255):
ColorDeepSupport 0x30 10/12/16/Y444 1/1/0/0
95 94 93 16 31 32 34 33 5 20 4 19 18 3 17 2 22 7 21 6 1 95 94 93 353 352
{1, 1, 0x7f, 0x07}
{2, 5, 0x07, 0x00}
{7, 1, 0x07, 0x07}
Speaker Allocation: 0x01
Vendor: 0xc03
MaxTMDSClock1 300 MHz
SCDC: 0
RR_Cap: 0
DeepColor
checkvalue: 0xa4b80000
what size screen use ? 1080p or 4k ?
Here it is:
Rx Brand Name: DON
Rx Product Name: DENON-AVR
Manufacture Week: 0
Physical size(cm): 122 x 68
EDID Version: 1.3
blk0 chksum: 0x96
Source Physical Address[a.b.c.d]: 4.5.0.0
ColorDeepSupport 0xb8 10/12/16/Y444 1/1/0/1
93 94 95 98 31 16 20 5 19 4 32 34 60 62 18 22 3 7 17 21 2 6 1 95 94 93 98 352 353 357 358
{1, 7, 0x7f, 0x07}
{7, 5, 0x1e, 0x00}
{2, 5, 0x07, 0x00}
{11, 7, 0x7e, 0x03}
{10, 7, 0x06, 0x03}
{12, 7, 0x7e, 0x03}
{11, 7, 0x7e, 0x01}
Speaker Allocation: 0x5f
Vendor: 0xc03
ColorMetry: 0xdf
SCDC: 0
RR_Cap: 0
HDR  DeepColor
checkvalue: 0x96430000
Rx Brand Name: DON
Manufacture Week: 0
Manufacture Year: 2014
EDID Version: 1.3
blk0 chksum: 0xe4
Source Physical Address[a.b.c.d]: 1.4.0.0
YCC support 0x03, VIC (native 16):
16 31 32 34 33 5 20 4 19 18 3 17 2 22 7 21 6 1 93 95 94 14 35 15 36 29 37 30 38 95 94 93 353 352
{1, 7, 0x7f, 0x07}
{2, 5, 0x07, 0x00}
{7, 5, 0x1e, 0x00}
{10, 7, 0x06, 0x00}
{11, 7, 0x7e, 0x01}
{12, 7, 0x7e, 0x00}
Vendor: 0xc03
SCDC: 0
RR_Cap: 0
  DeepColor
checkvalue: 0xe4da0000
Do you need the same by directly connect to the TV in 4K Resolution?
It would be helpful have both as you had it setup and directly connected to the TV
