Moved to a new country and hadn’t used my setup in a couple of weeks. Previously Bluetooth was working fine. Got my stuff unpacked today and set up my Odroid N2+ and now Bluetooth is no longer working. It says “No Bluetooth adapter found.” from the Bluetooth menu. Which of course previously it was using the built-in Bluetooth of the N2+. I tried upgrading to latest version, a hard reset, and finally a completely fresh install by reflashing a new image.
I’ve never had any adaptors for it other than the one for my backup remote, which is RF not Bluetooth. I’ve never used wifi, always plugged directly into ethernet. If I provide an old log for when Bluetooth was working would that show where the Bluetooth was coming from?
Nvm on the old logs. I guess the server cleans them after a while, I get a 404 now when I try to open them. I think I will have to buy an adaptor then, thanks for the response!
Here’s a thread discussing Bluetooth adapters known to work with in CE on N2/N2+, it’s a little long in the tooth, but should still be helpful if you’re in the market for an adapter.
