How can I upgrade bootloader?
I’ve been told Android 6 bootloader is not compatible with Corelec wich needs Android 7 bootloader.
It doesn’t boot. It’s stuck on a black screen right after CoreELEC Booting splash screen.
A5 Nexbox 1GB 16Gb
Android 6
Coming from LibreElec 9 Lepotato trying to install CorrElec 20 Generic.
Try to install slimBOXtv firmware with USB Burning Tool first, then install CoreELEC.
vpeter
25 September 2022 20:18
#5
Did you try the firmware mentioned above?
no, no version for A5 Nexbox wich is “Mali400”
A5 Nexbox 1GB 16Gb is using S905X, and this has Mali-450 GPU, not Mali-400 (see Amlogic - Wikipedia ).
Therefore the above image should work, worth a try. Just prepare to have the original Stock SW as backup option.
Okay. I installed aidans rom. And now i can boot Coreleec.
Tried CE 20 nightly first but when I logged successfully and tried to run Netflix it popped an error:
init ()missing two required keyword-only arguments: request and response
So I blamed it on the nightly build mistakingly. And now I am trying 19.5. Still Popped the same error thing. I almost regret downgrading.
Here’s a log http://ix.io/4bRw
Vasco
30 September 2022 06:00
#9
This is a known Netflix error. It’s been happening for the last 2 days.
opened 06:51PM - 27 Sep 22 UTC
Bug
Triage: Confirmed
### Netflix add-on version
1.18.10
### Operative systems used
Windows
### Ko… di version used
Kodi 19 (Matrix)
### Description of the bug
I open Netflix addon and when i press to select my profile i get the following error:
TypeError: __init__() missing 2 required keyword-only arguments: 'request' and 'response'
I also tried to open the addon from the Settings, Addons, My addons, Video addons menu, with the same result
### Steps to reproduce the behavior
Open Netflix addon
Press to select profile
### Debug log - mandatory
https://paste.kodi.tv/ukugisozor.kodi
### Possible fix
_No response_
### Additional context
_No response_
### Screenshots
_No response_
Vasco
30 September 2022 08:46
#10
In the comments of that GitHub issue there’s a test version for the Netflix addon with the changes to make it work. Give it a try.
It’s updated now. Fixed. New version out.
system
Closed
8 January 2023 23:04
#12
