[CE 20.5 and 21.3] Internal Wi-Fi: input/output error
“ssv6051” module (internal Wi-Fi for AZW W95 S905W Box) is slowing down the system and input/output error when trying to connect. It was working fine on CE 19.4 and still working on Android 7.1 (box firmware).
Workaround for now: use a USB Wi-Fi dongle and create a .conf file with blacklist ssv6051.
Hint:
The box is very old
CE 20.5/21.3 is EOL - no support
Maybe a good idea to stay on CE 19 with working WiFi or using an USB WiFi dongle
That was the gist of dropping the link.
If wanting official support follow the instructions, issues having to do with EOL software may have been fixed so try nightly.
If your device cannot run nightly then assume your device is unsupported.
Outside of official, maybe some user with your same device will come help.
