The config.ini setting ( coreelec='quiet toram disk=FOLDER=/dev/data') is instructing CE to mount the eMMC for /storage instead of USB. Unless that config.ini setting is modified, you don’t have to do anything special.
DTBs can still be updated by copying them to the /flash partition. Updates can be done normally through the regular update process.
I did a completely fresh install on USB using CE Official 2.1.1 (CoreELEC-Amlogic-ng.arm-21.1.1-Omega-Generic.img.gz) and the Reboot to eMMC option is not there.
Yes, but unfortunately it is only Android 9 and quite dated now.
FEL works with bugs on CCwGTV so the functionality is definitely there on newer AndroidTV releases. Is there a way to override the dovi.ko file that ships with AndroidOS to enable FEL without CE at all?
Initial inspection of the bootloader included with the recent ota update to the Kinhank G1 indicates that the device has been significantly locked down. It may no longer be able to boot from USB in order to run CE. Owners of this device that haven’t installed the ota update yet may wish to consider waiting for confirmation before installing the ota.
not sure if this has anything to do with it but someone messaged them on facebook like 6 hours before they sent OTA asking about Gig Ethernet , not sure what they wrote but I thought they would tell them about the developments from here and that the box will sell like hotcakes if they fixed Gig Ethernet and miraculously they sent an OTA like 6 hours later? what are the chances?
what if they realised the ramifications of keeping it unlocked. I don’t see a reason why they would want to lock it now.
this is so saddening
Not likely, Kinhank isn’t the one creating or maintaining the ATV firmware for the G1, and firmware changes take time, as well as more time to get through the google OTA process.
The timing of DV FEL and the lockdown are a coincidence.
I went to enable adb debugging on Kinhank G1 after booting the new firmware and no CE and it is asking for a password like this Imgur: The magic of the Internet
to get the certification maybe they had to lock. but It’s obvious they would sell much more now with having it unlocked. maybe someone should get in contact
