Did you perform new install just updated using tar file?
sc2_s905x4_sei_smb_280.dtb Is available since 9/4 nightly. If no changes made then we don’t expect Ethernet to work beside this workaround.
I was using this one ( sc2_s905x4_ugoos_x4.dtb) with working Ethernet, until todays update, then the Ethernet stopped working. Something changed with this device tree today.
Nothing changed, no.
https://relkai.coreelec.org/?dir=Amlogic-ng/ce-21
I guess that will remain one of life’s mysteries.
I was watching "Saving Pvt. Ryan, and it downloaded the newest update, and asked me if I wanted to reboot. I rebooted, and after it rebooted, I no longer had any Ethernet connection.
I agree that does not make sense, but that is what happened.
No log no problem…
Yes correct
NE 5.4.210 no profile 7 FEL
However conversion of MEL playback
Have many boxes in the Field
Friends and Family all want CoreELEC!!!
Dolby Vision!!!
Have Ugoos Am6b Plus at home
And most reliable Tanix Tx5 Plus Deluxe!!!
Big price difference between Homatics and older
Ugoos x4q extra
Ugoos Box X4q extra is only arnd $80 US
Sale at aliexpress .com
Iam sure Homatics is a Fine choice also
This Hobby gets addictive/expensive!!!
ng-0904/0908/0910, there is no Ethernet, need to boot to Android, and then back to CE from Android to have Ethernet.
https://discourse.coreelec.org/t/homatics-box-r-4k-plus/19596/2471
https://discourse.coreelec.org/t/homatics-box-r-4k-plus/19596/2497
I’ve been told that the aliexpress sale isn’t special. wait for real sales later on. also the AMB6+ was actually cheaper on Ugoos site earlier today, they had a $10 off. I expect best sales around black friday in like 6 weeks time
now with all this coreelec developement I expect boxes to compete and reduce in price. in 6 months we should have lots of chinese sellers with FEL capable chips
Curious test: try to play a relatively high bitrate 1080p24 VC-1 encoded video, and set the VC-1 acceleration to exclude 24p. That setting is because the Amlogic VC-1 hardware decoder incorrectly deinterlaces all VC-1 content, even progressive.
Software decoding 1080p VC-1 with the S922X-J SoC seems close to capping on a single core. So not sure if the S905X4-J can handle it. I think software decoding is single threaded?
S905X4 can’t handle it, I tried, lucky I could replace those handful VC1 movies with HEVC/H264 ones.
We have asked Homatics about vc-1 hw decoder, a long time ago.
They said its dropped.
Its a very old format, they will not support it anymore.
The VC-1 issue might be a software bug in the hardware decoder, but nobody really dig into it.
FYI, I spent a few hours looking before, I could get it decoding without interlace but some frame rate issue, I think it is using a different path to other HW decoders (older approach) need an expert.
Still no ethernet.WIFI auto-connection failed.0911-ng
Your device id5 is using Motorcomm YT8531, this eth chip is not supported in 4.9 kernel. Please someone backport the driver and feel free to make a PR.
What I don’t understand is why there is ethernet from android back to ce
Were you using 21.1.1 NG stable?
I can’t get my ethernet to work with either the generic dtb or the sei one. This is only nightly.
Edit: Nvm after 2 complete device power offs, it appeared with the generic dtb.
Edit2: DV not working though. DoVi driver isn’t loading.
Do I need to be on a specific Android version? I was under the impression that CE-NG provides its own kernel.
In AndroidTV it shows as Kernel 5.4.242-ab5221, Nokia SW Version v12.8.5221
[   14.204939@0]- [TEE] E/TA:   MM-module-name:Video firmware TA,Version:1.0.1-gb173c81(build:369)
[   14.204944@0]- [TEE] E/TA:   fw_check_pack_version:282 the package has 110 fws totally.
[   14.204946@0]- [TEE] E/TA:   fw_check_pack_version:299 The TA ver is v1.0
[   14.204947@0]- [TEE] E/TA:   fw_check_pack_version:300 The fw ver is v0.3
[   14.204948@0]- [TEE] E/TA:   fw_data_insert:379 the fw with 520 KB will be loaded.
[   14.204950@0]- [TEE] M/TA: TEE_Video_Load_FW success
[   14.214545@0]- dovi: disagrees about version of symbol module_layout
[   14.214560@0]- dovi: module license 'AML' taints kernel.
[   14.214561@0]- Disabling lock debugging due to kernel taint
[   14.216154@0]- dovi: disagrees about version of symbol register_dv_functions
[   14.217241@0]- *** amlogic_dolby_vision_init dv: null ***
[   14.217248@0]- *** register_dv_stb_functions.***
[   14.217334@0]- hdr10_policy 115, ko_info THE GOLDEN FLUENT TECHNOLOGY AND SCIENCE HK LIMITED [stb:2.4:e]-[v1.0]-[ Mon Oct 5 20:07:12 CST 2020]-[ brian.zhu]-[* stb_2.4]-[18510d0c6c2246e2fe28c45ae9f71b68e2bd23fa]-[Date: Sat Oct 3 21:25:19 2020 -0700]-[0]
[   14.217338@0]- efuse_mode=0 reg_value = 0x18
[   14.217339@0]- dv capability 7
Edit3: Using my DV capable TV, the options show up. This is with the dovi.ko for the 922X, not the 904X5, interestingly enough. P7 FEL working too according to test files.
@bluesea Please try with this test image:
Reboot repeatedly, cannot enter CE
