CE setup buttons are problematic for colour blind
The button (dot) itself wasn’t changed but it also has a texture image and I was wondering if its visibility changes for you focused and non-focused. Same for the buttons themselves, are all buttons hard to read or is it based on their focus?
The slider dot appears to be the same to me focused and non-focused. This may be due to its bright white colour.
Obvs this is different with the buttons’ colourings which are not white.
When you say “are all buttons hard to read”, if you are referring to the button’s text, then no it is easily readable since it appears to be white and so contrasts well with the surrounding colour.
As before, the fundamental issue was determining the buttons’ focus state due to the lack of difference in the buttons’ colours, for the reasons previously identified, and which is now fixed and which will hopefully soon make it into a release.
If you could let me know the mechanism for a CE Pull Request that would be great as I’m not familiar with that process (for CE).
Good news: the proposed accessibility change has now been accepted and merged into the CoreELEC 22 branch:
https://github.com/CoreELEC/service.coreelec.settings/pull/35
The setup wizard’s local focus and no-focus texture overrides have been removed from the affected controls, allowing a much clearer focused-button state for colour-blind users.
Many thanks to @emveepee for the suggested changes, @arthur-libermanarthur-liberman for reviewing the screenshots and to @Portisch for merging the change.
