I have two TV’s, each connected to a device running coreelec.
1st setup:
TCL 4 series running Roku TV OS, connected to a Ugoos X2 running coreelec.
2nd setup:
TCL 5 series running Roku TV OS, connected to an Odroid N2 running coreelec.
My problem:
On the second setup, I can use only the Roku remote, whenever I select the input
that the N2 is on the remote begins to control the N2, this is what I am going for
because this being a simple bedroom setup I would like one remote.
On the first setup the TV remote will not control the Ugoos X2. I have the CEC settings
on both devices and both TV’s the same, but one works and the other doesn’t.
On the problematic setup, the X2 is seen as a CEC device, and things like automatically
changing the input are happening, it’s just that the remote won’t work for the X2.
Can anyone think of something I might be missing here? I know CEC is fussy, but it is odd since
these setups are so similar. When I get a chance I plan on swapping the CE devices between
TV’s to see if that has any change.
