Color problem in playback
I have a 905X bo with latest CoreElec image.
The problem is that in playbak, it use change the color of the playback and I need to stop and play again.
Here is a example:
Is possible to fix it?
Kind regards.
Try a new HDMI cable or switch the HDMI port on TV and give feedback.
If that’s not working, maybe this will help Green screen.
Edit: not the problem I thought.
This can b deleted - apologies.
@jlazkano did you ever manage to fix this issue? I am encountering the same thing with a S905X box, CoreELEC and a Sony Bravia TV. I have already used a new HDMI cable but it did not fix the issue. Neither did enabling “Use 4:2:2 colour subsampling”.
Switching the input on the TV and switching back fixes the colours temporarily. Just waiting also fixes the colours after a while, so it just randomly switches between normal colours and these inverted / blue tinted colours. And the timing seems fairly random as well, sometimes it takes 30 mins until it happens, sometimes it happens after 5, sometimes it only takes a few minutes to switch back, sometimes it stays with the weird colours for a while. The settings overlay of the TV looks fine, so it is just the input video that has these weird colours.
How it looks:
How it is supposed to look:
Actually Color space issues - #7 by smg04 seems to have fixed the issue.
I try the command of the link:
# echo \"rgb,now\" > /sys/class/amhdmitx/amhdmitx0/attr
But it doesn’t save well the code:
# cat /sys/class/amhdmitx/amhdmitx0/attr
"rgb,
Need I execute in some different way?
Regards.
