I’d like to join Khadas Vim3l, but I have a problem. Emmc has an installed 9.2.7. I would like to upgrade this to version 19.1
I’ve read the warning. I checked and my current installation does not contain a dtb file in the flash folder. I tried to copy it but failed. I would have tried to transfer a fresh system from an Sd card using ceemmc command but failed. Error message:
Thank you for reading this too.
I was hoping there was an easier/quicker solution. Not everyone is a programmer…
For a supported box, I don’t understand why you have to complicate an upgrade like this…
Thank you, I will not update this box then.
You powering the VIM from a PC USB port? If yes, then use a “normal” power supply. Otherwise the upgrade mode is starting and it’s not trying to load from uSD/USB. Just tested and with power supply it
's just working fine.
No. I start from a normal power supply. Is the upgrade mode restored after power off? Or do I have to exit it somehow?
I’ll describe what I’ve done so far:
installed krescue online, then installed an android version from there
booted from card to coreelec, but ceemmc did not work
upgraded to a different version with usb burning tool at your request
Long press the Power key without releasing it.
Short press the ‘Reset’ key and release it.
Count to 10 seconds and release the ‘Power’ key to enter into upgrade mode.
Ok. Thanks for your help and patience. I did it! I was the amateur
It starts from sd card and the ceemmc command worked. I converted the system to emmc.
There are a few things that are strange:
Very slow to shutdown/reboot the system (more than 5 minutes per reboot. It’s like it freezes)
blue led lights up after power off (only the white one used to light up but after power off it doesn’t light up anymore)
Am I getting the right feeling that something is wrong with this?
Hi, i found new bug after upgrade from before realises. On 19.1 on device x88king is not going the wakeup over lan. I had never trouble before with wol on this device. http://ix.io/3nPR
When I understand that correctly this version 19.1 is not yet working for S905 in my case a Minix Neo U1, is that in the making or is 9.2.x the last supported version for this Hardware?
Ok so i seem to have gotten 9.2.7 working on my C2 as of now but my N2 9.1 still does not work so i am not sure if there is an issue or does this only work on an N2+ ?
