CoreELEC 19.1-Matrix (May 12th, 2021)
CoreELEC 19.1-Matrix is now available. It was a rather short development cycle this time around, which saw the CoreELEC developers focusing on fixing the most common issues reported with the 19.0-Matrix release.
Changes Since 19.0-Matrix
  • Fixed issues with CEC on screensaver
  • Fixed rare issue with some resolutions not being available
  • Fixed a couple small update issues
  • Updated dav1d to 0.8.2 (This provides best available software decoding of AV1 content)
  • Improved inject_bl301 now supports more boot loader versions
  • Improved handling of older devices for ceemmc
  • Fixed some Bluetooth connection problems
  • Fixed building CoreELEC on aarch64 docker platform
  • Updated several packages
  • ceemmc: fix bug by char/integer compare on old systems
  • Add RTL8188FTV-aml wifi driver, thx to Stane1983
  • Implemented Wifi driver QCA6174
  • Implemented RTL8761B Bluetooth device
  • Updated Wifi driver ssv6xxx-aml
  • Implemented Wifi driver SSV6030P
  • Add option for Khadas VIM3(l) to switch wired network interface from ‘default’ to ‘M.2 Slot’
  • Fix LPCM with some AVRs and set the correct codec for DTS-HD
  • Add an option to allow playing DTS-HD as LPCM
  • CoreELEC-settings: add option to backup thumbnails
  • Kodi: add option to disable DTS-HD Core fallback
  • Added dt_id device specific option for dtb-xml
  • H264: Let Kodi decide if 1080p25 should be handled as 1080i50 or not
  • Fix flickering on stream start when using software decoder
  • Include C.UTF-8 locale as default to avoid Python3 encoding issues
Downloads:
Discussion thead:
