Why didnāt I think of that⦠Yup sure could; thanks for the reminder, Sholander !
Try please install default controller. I had from oldest release on device but was not marked as installed, but do it all ok. After try reinstall on on 1.0.8 is not installed:Add-on:Default Controller - Official Kodi Wiki
I have a problem after removing the SD media the boot returns to android!
Tell me where is the error?
indent preformatted text by 4 spaceslogin as: root
root@192.XXX.X.XXX's password:
# CoreELEC #
# https://coreelec.org #
CoreELEC (community): 19.1-Matrix_devel_20210402005658 (Amlogic-ng.arm)
CoreELEC:~ # cemmc-x
-sh: cemmc-x: not found
CoreELEC:~ # ceemmc -x
Starting CoreELEC eMMC installation tool...
System is not supported: gxl_p230_k1_pro!
There is NO official support by Team CoreELEC
if you continue to run this tool!
Continue? [y]: y
There is NO official support...
Just do not use the tool on this deviceā¦
My a95x max box upgraded to rc1 yesterdayā¦will thatās what happens when you have automatic update set
So far all good - had to remap the ir remote, but there is good detailed help on the web
So far only one issue, boot with monitor off, and itās impossible to get the screen on again. Didnāt happen with previously release. Not necessarily a problem as I run it headless most of the time and control via hhtp/kore and āmessā with it using ssh and sometimes need the screen
great job
Thatās a common problem. Good News is, there is a workaround.
Look here:
But why? This tool fine working on ki pro, only on official realise RC1 was error āAbortedā, but last nightly build all done without errors and working perfectlyā¦
Perhaps install last nightly
cd .update
wget https://relkai.coreelec.org/ce-19/CoreELEC-Amlogic-ng.arm-19.1-Matrix_nightly_20210404.tar
reboot
move to interlal
ceemmc -x
after this
return RC1
cd .update
wget https://github.com/CoreELEC/CoreELEC/releases/download/19.1-Matrix_rc1/CoreELEC-Amlogic-ng.arm-19.1-Matrix_rc1.tar
reboot
Thereās no official support for no supported devices but if you read some posts above yours you can see there was a bug that was addressed in the nightlies.
iāve updated from 9.2.7 to 19.1 rc1 and my smb shares stopped to work.
It seems like the dns resolving does not work.
INFO <general>: VideoPlayer::OpenFile: smb://SERVER2008/BluRays/***.mkv
2021-04-05 17:33:29.122 T:4848 INFO <general>: Creating InputStream
2021-04-05 17:33:31.217 T:4788 INFO <general>: SMBFile->Open: Unable to open file : '
smb://172.25.32.1/BluRays/***.mkv'
unix_err:'6e' error : 'Connection timed out'
IP of server is 192.168.178.20, and can be pinged via ssh without error using hostname.
Tried to change min/max smb version in smb-client options, but no success.
Any suggestions?
Itās recommended to make a clean install.
Already tried clean install, using my āoldā sources.xml. Same problem.
Clean install using IP instead of hostname in sources.xml works, but not willing to rebuild my whole sql database at the moment.
Will go back to 9.2.7
hostname never worked here with win10. Only IP is āreallyā working.
Ok, thanks.
Worked flawless till CE 19.0.
Then i have to rework my library some time.
If you know phpmyadmin you can use it to connect to your (if you use) MYSQL or MARIADB database and replace your hostname with the ip adresse by search and replace. Done this a lot of times cause none of my friends wonāt hear and they uses hostnames also
Greetz,
J.
@mav20 :
Try change the max smb version in Kodi.
Maybe it works.
Just an ideaā¦
No audio (sometimes) on randomly picked Live TV channels. Any channel picked sometimes will do this.
Attached parts of log where this can be seen:
Summary
2021-04-07 20:27:36.153 T:5152 ERROR <general>: [ script.embuary.helper ] Image error: Could not get image for http://localhost:9981/imagecache/69 (try 1) -> [Errno 2] No such file or directory: '/storage/.kodi/userdata/addon_data/script.embuary.helper/img/tmp/0501d965e55280d32ebab81e791c69ea.jpg'
2021-04-07 20:27:36.534 T:5056 INFO <general>: VideoPlayer::OpenFile: pvr://channels/tv/Svi%20programi/pvr.hts_1643347170.pvr
2021-04-07 20:27:36.566 T:13774 INFO <general>: Creating InputStream
2021-04-07 20:27:36.571 T:13774 INFO <general>: Creating Demuxer
2021-04-07 20:27:36.572 T:13774 INFO <general>: Opening stream: 1001 source: 256
2021-04-07 20:27:36.572 T:13774 WARNING <general>: OpenStream - Unsupported stream 1001. Stream disabled.
2021-04-07 20:27:36.572 T:13774 INFO <general>: Closing stream player 2
2021-04-07 20:27:36.573 T:13774 INFO <general>: waiting for video thread to exit
2021-04-07 20:27:36.573 T:13825 ERROR <general>: Got MSGQ_ABORT or MSGO_IS_ERROR return true
2021-04-07 20:27:36.573 T:13825 INFO <general>: thread end: video_thread
2021-04-07 20:27:36.573 T:13774 INFO <general>: deleting video codec
2021-04-07 20:27:36.574 T:13774 INFO <general>: Opening stream: 1002 source: 256
2021-04-07 20:27:36.574 T:13774 INFO <general>: Finding audio codec for: 86018
2021-04-07 20:27:36.576 T:13774 INFO <general>: CDVDAudioCodecFFmpeg::Open() Successful opened audio decoder aac
2021-04-07 20:27:36.576 T:13774 INFO <general>: Opening stream: 1003 source: 256
2021-04-07 20:27:36.576 T:13774 INFO <general>: waiting for teletext data thread to exit
2021-04-07 20:27:36.580 T:13774 INFO <general>: Creating teletext data thread
2021-04-07 20:27:36.580 T:13837 INFO <general>: running thread: CDVDTeletextData
2021-04-07 20:27:36.673 T:5152 WARNING <general>: xbmc.translatePath is deprecated and might be removed in future kodi versions. Please use xbmcvfs.translatePath instead.
2021-04-07 20:27:36.811 T:13774 INFO <general>: Opening stream: 1001 source: 256
2021-04-07 20:27:36.812 T:13774 INFO <general>: CVideoPlayerVideo::OpenStream - Creating codec: 173
2021-04-07 20:27:36.812 T:13774 INFO <general>: CBitstreamConverter::Open Invalid hvcC
2021-04-07 20:27:36.812 T:13774 INFO <general>: DVDVideoCodecAmlogic: Opened Amlogic Codec
2021-04-07 20:27:36.812 T:13774 INFO <general>: Creating video thread
2021-04-07 20:27:36.812 T:13838 INFO <general>: running thread: video_thread
2021-04-07 20:27:36.812 T:13774 INFO <general>: Opening stream: 1002 source: 256
2021-04-07 20:27:36.813 T:13774 INFO <general>: Opening stream: 1003 source: 256
2021-04-07 20:27:36.819 T:13838 INFO <general>: DVDVideoCodecAmlogic::AddData Open decoder: fps:50/1
2021-04-07 20:27:36.826 T:13823 INFO <general>: CDVDAudioCodecFFmpeg::Open() Successful opened audio decoder aac
2021-04-07 20:27:37.205 T:5152 WARNING <general>: xbmc.translatePath is deprecated and might be removed in future kodi versions. Please use xbmcvfs.translatePath instead.
2021-04-07 20:27:37.218 T:5152 INFO <general>: Skipped 1 duplicate messages..
2021-04-07 20:27:37.218 T:5152 ERROR <general>: CCurlFile::Open failed with code 404 for http://localhost:9981/imagecache/69:
2021-04-07 20:27:37.219 T:5152 ERROR <general>: Open - <http://localhost:9981/imagecache/69> failed to open
2021-04-07 20:27:37.220 T:5152 ERROR <general>: [ script.embuary.helper ] Image error: Could not get image for http://localhost:9981/imagecache/69 (try 2) -> [Errno 2] No such file or directory: '/storage/.kodi/userdata/addon_data/script.embuary.helper/img/tmp/0501d965e55280d32ebab81e791c69ea.jpg'
2021-04-07 20:27:37.451 T:5056 INFO <general>: VideoPlayer::OpenFile: pvr://channels/tv/Svi%20programi/pvr.hts_1587284816.pvr
2021-04-07 20:27:37.537 T:5152 WARNING <general>: xbmc.translatePath is deprecated and might be removed in future kodi versions. Please use xbmcvfs.translatePath instead.
2021-04-07 20:27:37.659 T:13774 INFO <general>: Creating InputStream
2021-04-07 20:27:37.674 T:13774 INFO <general>: Creating Demuxer
2021-04-07 20:27:37.675 T:13774 INFO <general>: Opening stream: 1001 source: 256
2021-04-07 20:27:37.675 T:13774 WARNING <general>: OpenStream - Unsupported stream 1001. Stream disabled.
2021-04-07 20:27:37.675 T:13774 INFO <general>: Closing stream player 2
2021-04-07 20:27:37.675 T:13774 INFO <general>: waiting for video thread to exit
2021-04-07 20:27:37.675 T:13838 ERROR <general>: Got MSGQ_ABORT or MSGO_IS_ERROR return true
2021-04-07 20:27:37.675 T:13838 INFO <general>: thread end: video_thread
2021-04-07 20:27:37.675 T:13774 INFO <general>: deleting video codec
2021-04-07 20:27:37.685 T:13774 INFO <general>: Opening stream: 1002 source: 256
2021-04-07 20:27:37.685 T:13774 INFO <general>: Finding audio codec for: 86018
2021-04-07 20:27:37.687 T:13774 INFO <general>: CDVDAudioCodecFFmpeg::Open() Successful opened audio decoder aac
2021-04-07 20:27:37.688 T:13774 INFO <general>: Closing stream player 4
2021-04-07 20:27:37.688 T:13774 INFO <general>: waiting for teletext data thread to exit
2021-04-07 20:27:37.688 T:13837 ERROR <general>: Got MSGQ_ABORT or MSGO_IS_ERROR return true (-1)
2021-04-07 20:27:37.689 T:13837 INFO <general>: thread end: data_thread
2021-04-07 20:27:37.902 T:13774 INFO <general>: Opening stream: 1001 source: 256
2021-04-07 20:27:37.902 T:13774 INFO <general>: CVideoPlayerVideo::OpenStream - Creating codec: 173
2021-04-07 20:27:37.903 T:13774 INFO <general>: CBitstreamConverter::Open Invalid hvcC
2021-04-07 20:27:37.903 T:13774 INFO <general>: DVDVideoCodecAmlogic: Opened Amlogic Codec
2021-04-07 20:27:37.903 T:13774 INFO <general>: Creating video thread
2021-04-07 20:27:37.903 T:13849 INFO <general>: running thread: video_thread
2021-04-07 20:27:37.904 T:13774 INFO <general>: Opening stream: 1002 source: 256
2021-04-07 20:27:37.904 T:13849 INFO <general>: DVDVideoCodecAmlogic::AddData Open decoder: fps:50/1
2021-04-07 20:27:37.916 T:13823 INFO <general>: CDVDAudioCodecFFmpeg::Open() Successful opened audio decoder aac
2021-04-07 20:27:37.957 T:5152 WARNING <general>: xbmc.translatePath is deprecated and might be removed in future kodi versions. Please use xbmcvfs.translatePath instead.
2021-04-07 20:27:37.963 T:5152 ERROR <general>: CCurlFile::Open failed with code 404 for http://localhost:9981/imagecache/69:
2021-04-07 20:27:37.963 T:5152 ERROR <general>: Open - <http://localhost:9981/imagecache/69> failed to open
2021-04-07 20:27:37.963 T:5152 ERROR <general>: [ script.embuary.helper ] Image error: Could not get image for http://localhost:9981/imagecache/69 (try 3) -> [Errno 2] No such file or directory: '/storage/.kodi/userdata/addon_data/script.embuary.helper/img/tmp/0501d965e55280d32ebab81e791c69ea.jpg'
2021-04-07 20:27:38.172 T:5152 WARNING <general>: xbmc.translatePath is deprecated and might be removed in future kodi versions. Please use xbmcvfs.translatePath instead.
2021-04-07 20:27:38.477 T:5152 ERROR <general>: CCurlFile::Open failed with code 404 for http://localhost:9981/imagecache/69:
2021-04-07 20:27:38.477 T:5152 ERROR <general>: Open - <http://localhost:9981/imagecache/69> failed to open
2021-04-07 20:27:38.477 T:5152 ERROR <general>: [ script.embuary.helper ] Image error: Could not get image for http://localhost:9981/imagecache/69 (try 2) -> [Errno 2] No such file or directory: '/storage/.kodi/userdata/addon_data/script.embuary.helper/img/tmp/0501d965e55280d32ebab81e791c69ea.jpg'
2021-04-07 20:27:38.982 T:5152 ERROR <general>: CCurlFile::Open failed with code 404 for http://localhost:9981/imagecache/69:
2021-04-07 20:27:38.983 T:5152 ERROR <general>: Open - <http://localhost:9981/imagecache/69> failed to open
2021-04-07 20:27:38.984 T:5152 ERROR <general>: [ script.embuary.helper ] Image error: Could not get image for http://localhost:9981/imagecache/69 (try 3) -> [Errno 2] No such file or directory: '/storage/.kodi/userdata/addon_data/script.embuary.helper/img/tmp/0501d965e55280d32ebab81e791c69ea.jpg'
2021-04-07 20:27:39.001 T:5056 INFO <general>: VideoPlayer::OpenFile: pvr://channels/tv/Svi%20programi/pvr.hts_1630659906.pvr
2021-04-07 20:27:39.079 T:13774 INFO <general>: Creating InputStream
2021-04-07 20:27:39.086 T:13774 INFO <general>: Creating Demuxer
2021-04-07 20:27:39.086 T:13774 INFO <general>: Closing stream player 2
2021-04-07 20:27:39.087 T:13774 INFO <general>: waiting for video thread to exit
2021-04-07 20:27:39.087 T:13849 ERROR <general>: Got MSGQ_ABORT or MSGO_IS_ERROR return true
2021-04-07 20:27:39.088 T:13849 INFO <general>: thread end: video_thread
2021-04-07 20:27:39.088 T:13774 INFO <general>: deleting video codec
2021-04-07 20:27:39.092 T:13774 INFO <general>: Closing stream player 1
2021-04-07 20:27:39.092 T:13774 INFO <general>: Waiting for audio thread to exit
2021-04-07 20:27:39.102 T:13823 INFO <general>: thread end: CVideoPlayerAudio::OnExit()
2021-04-07 20:27:39.104 T:13774 INFO <general>: Closing audio device
2021-04-07 20:27:39.106 T:13774 INFO <general>: Deleting audio codec
2021-04-07 20:27:39.198 T:5152 WARNING <general>: xbmc.translatePath is deprecated and might be removed in future kodi versions. Please use xbmcvfs.translatePath instead.
2021-04-07 20:27:39.279 T:5089 INFO <general>: CActiveAESink::OpenSink - initialize sink
2021-04-07 20:27:39.281 T:5089 INFO <general>: CAESinkALSA::Initialize - Attempting to open device "hdmi:CARD=AMLMESONAUDIO,DEV=0"
2021-04-07 20:27:39.294 T:5089 INFO <general>: CAESinkALSA::Initialize - Opened device "hdmi:CARD=AMLMESONAUDIO,DEV=0,AES0=0x04,AES1=0x82,AES2=0x00,AES3=0x00"
2021-04-07 20:27:39.296 T:5089 INFO <general>: CAESinkALSA::InitializeHW - Your hardware does not support AE_FMT_FLOAT, trying other formats
2021-04-07 20:27:39.296 T:5089 INFO <general>: CAESinkALSA::InitializeHW - Using data format AE_FMT_S16NE
2021-04-07 20:27:39.514 T:5152 WARNING <general>: xbmc.translatePath is deprecated and might be removed in future kodi versions. Please use xbmcvfs.translatePath instead.
2021-04-07 20:27:39.532 T:5152 ERROR <general>: CCurlFile::Open failed with code 404 for http://localhost:9981/imagecache/69:
2021-04-07 20:27:39.533 T:5152 ERROR <general>: Open - <http://localhost:9981/imagecache/69> failed to open
2021-04-07 20:27:39.533 T:5152 ERROR <general>: [ script.embuary.helper ] Image error: Could not get image for http://localhost:9981/imagecache/69 (try 2) -> [Errno 2] No such file or directory: '/storage/.kodi/userdata/addon_data/script.embuary.helper/img/tmp/0501d965e55280d32ebab81e791c69ea.jpg'
2021-04-07 20:27:40.040 T:5152 ERROR <general>: CCurlFile::Open failed with code 404 for http://localhost:9981/imagecache/69:
2021-04-07 20:27:40.040 T:5152 ERROR <general>: Open - <http://localhost:9981/imagecache/69> failed to open
2021-04-07 20:27:40.041 T:5152 ERROR <general>: [ script.embuary.helper ] Image error: Could not get image for http://localhost:9981/imagecache/69 (try 3) -> [Errno 2] No such file or directory: '/storage/.kodi/userdata/addon_data/script.embuary.helper/img/tmp/0501d965e55280d32ebab81e791c69ea.jpg'
2021-04-07 20:27:41.269 T:13774 INFO <general>: Opening stream: 1001 source: 256
2021-04-07 20:27:41.269 T:13774 WARNING <general>: OpenStream - Unsupported stream 1001. Stream disabled.
2021-04-07 20:27:41.270 T:13774 INFO <general>: Opening stream: 1002 source: 256
2021-04-07 20:27:41.270 T:13774 INFO <general>: Finding audio codec for: 86016
2021-04-07 20:27:41.270 T:13774 INFO <general>: CDVDAudioCodecFFmpeg::Open() Successful opened audio decoder mp2
2021-04-07 20:27:41.270 T:13774 INFO <general>: Creating audio thread
2021-04-07 20:27:41.271 T:13866 INFO <general>: running thread: CVideoPlayerAudio::Process()
2021-04-07 20:27:41.271 T:13774 INFO <general>: Opening stream: 1006 source: 256
2021-04-07 20:27:41.272 T:13774 INFO <general>: Opening stream: 1003 source: 256
2021-04-07 20:27:41.272 T:13774 INFO <general>: waiting for teletext data thread to exit
2021-04-07 20:27:41.273 T:13774 INFO <general>: Creating teletext data thread
2021-04-07 20:27:41.274 T:13867 INFO <general>: running thread: CDVDTeletextData
2021-04-07 20:27:41.373 T:13774 INFO <general>: Opening stream: 1001 source: 256
2021-04-07 20:27:41.373 T:13774 INFO <general>: CVideoPlayerVideo::OpenStream - Creating codec: 27
2021-04-07 20:27:41.373 T:13774 INFO <general>: DVDVideoCodecAmlogic: Opened Amlogic Codec
2021-04-07 20:27:41.373 T:13774 INFO <general>: Creating video thread
2021-04-07 20:27:41.373 T:13868 INFO <general>: running thread: video_thread
2021-04-07 20:27:41.374 T:13774 INFO <general>: Opening stream: 1002 source: 256
2021-04-07 20:27:41.374 T:13774 INFO <general>: Finding audio codec for: 86016
2021-04-07 20:27:41.374 T:13774 INFO <general>: CDVDAudioCodecFFmpeg::Open() Successful opened audio decoder mp2
2021-04-07 20:27:41.374 T:13774 INFO <general>: Closing stream player 3
2021-04-07 20:27:41.374 T:13774 INFO <general>: Opening stream: 1006 source: 256
2021-04-07 20:27:41.374 T:13774 INFO <general>: Opening stream: 1003 source: 256
2021-04-07 20:27:41.374 T:13868 INFO <general>: DVDVideoCodecAmlogic::AddData Open decoder: fps:25/1
2021-04-07 20:27:41.384 T:13866 INFO <general>: Creating audio stream (codec id: 86016, channels: 2, sample rate: 48000, no pass-through)
2021-04-07 20:27:41.387 T:5089 INFO <general>: CActiveAESink::OpenSink - initialize sink
2021-04-07 20:27:41.387 T:5089 INFO <general>: CAESinkALSA::Initialize - Attempting to open device "hdmi:CARD=AMLMESONAUDIO,DEV=0"
2021-04-07 20:27:41.402 T:5089 INFO <general>: CAESinkALSA::Initialize - Opened device "hdmi:CARD=AMLMESONAUDIO,DEV=0,AES0=0x04,AES1=0x82,AES2=0x00,AES3=0x02"
2021-04-07 20:27:41.405 T:5089 INFO <general>: CAESinkALSA::InitializeHW - Your hardware does not support AE_FMT_FLOAT, trying other formats
2021-04-07 20:27:41.405 T:5089 INFO <general>: CAESinkALSA::InitializeHW - Using data format AE_FMT_S16NE
2021-04-07 20:27:41.559 T:5152 WARNING <general>: xbmc.translatePath is deprecated and might be removed in future kodi versions. Please use xbmcvfs.translatePath instead.
2021-04-07 20:27:42.215 T:13868 INFO <general>: Skipped 2 duplicate messages..
2021-04-07 20:27:42.215 T:13868 WARNING <general>: OutputPicture - timeout waiting for buffer
2021-04-07 20:27:44.068 T:5056 INFO <general>: Skipped 2 duplicate messages..
2021-04-07 20:27:44.068 T:5056 INFO <general>: VideoPlayer::OpenFile: pvr://channels/tv/Svi%20programi/pvr.hts_1587284816.pvr
2021-04-07 20:27:44.092 T:13868 WARNING <general>: OutputPicture - timeout waiting for buffer
2021-04-07 20:27:44.118 T:13774 INFO <general>: Creating InputStream
2021-04-07 20:27:44.126 T:13774 INFO <general>: Creating Demuxer
2021-04-07 20:27:44.126 T:13774 INFO <general>: Closing stream player 2
2021-04-07 20:27:44.127 T:13868 ERROR <general>: Got MSGQ_ABORT or MSGO_IS_ERROR return true
2021-04-07 20:27:44.127 T:13868 INFO <general>: thread end: video_thread
2021-04-07 20:27:44.127 T:13774 INFO <general>: waiting for video thread to exit
2021-04-07 20:27:44.127 T:13774 INFO <general>: deleting video codec
2021-04-07 20:27:44.130 T:13774 INFO <general>: Closing stream player 1
2021-04-07 20:27:44.130 T:13774 INFO <general>: Waiting for audio thread to exit
2021-04-07 20:27:44.140 T:13866 INFO <general>: thread end: CVideoPlayerAudio::OnExit()
2021-04-07 20:27:44.142 T:13774 INFO <general>: Closing audio device
2021-04-07 20:27:44.144 T:13774 INFO <general>: Deleting audio codec
2021-04-07 20:27:44.144 T:13774 INFO <general>: Closing stream player 3
2021-04-07 20:27:44.144 T:13774 INFO <general>: Closing stream player 4
2021-04-07 20:27:44.144 T:13774 INFO <general>: waiting for teletext data thread to exit
2021-04-07 20:27:44.144 T:13867 ERROR <general>: Got MSGQ_ABORT or MSGO_IS_ERROR return true (-1)
2021-04-07 20:27:44.145 T:13867 INFO <general>: thread end: data_thread
2021-04-07 20:27:44.155 T:5152 WARNING <general>: xbmc.translatePath is deprecated and might be removed in future kodi versions. Please use xbmcvfs.translatePath instead.
2021-04-07 20:27:44.314 T:5089 INFO <general>: CActiveAESink::OpenSink - initialize sink
2021-04-07 20:27:44.316 T:5089 INFO <general>: CAESinkALSA::Initialize - Attempting to open device "hdmi:CARD=AMLMESONAUDIO,DEV=0"
2021-04-07 20:27:44.329 T:5089 INFO <general>: CAESinkALSA::Initialize - Opened device "hdmi:CARD=AMLMESONAUDIO,DEV=0,AES0=0x04,AES1=0x82,AES2=0x00,AES3=0x00"
2021-04-07 20:27:44.330 T:5089 INFO <general>: CAESinkALSA::InitializeHW - Your hardware does not support AE_FMT_FLOAT, trying other formats
2021-04-07 20:27:44.330 T:5089 INFO <general>: CAESinkALSA::InitializeHW - Using data format AE_FMT_S16NE
2021-04-07 20:27:47.712 T:13774 INFO <general>: Opening stream: 1001 source: 256
2021-04-07 20:27:47.712 T:13774 WARNING <general>: OpenStream - Unsupported stream 1001. Stream disabled.
2021-04-07 20:27:47.921 T:13774 INFO <general>: Opening stream: 1001 source: 256
2021-04-07 20:27:47.921 T:13774 INFO <general>: CVideoPlayerVideo::OpenStream - Creating codec: 173
2021-04-07 20:27:47.921 T:13774 INFO <general>: CBitstreamConverter::Open Invalid hvcC
2021-04-07 20:27:47.921 T:13774 INFO <general>: DVDVideoCodecAmlogic: Opened Amlogic Codec
2021-04-07 20:27:47.921 T:13774 INFO <general>: Creating video thread
2021-04-07 20:27:47.921 T:13879 INFO <general>: running thread: video_thread
2021-04-07 20:27:47.922 T:13879 INFO <general>: DVDVideoCodecAmlogic::AddData Open decoder: fps:50/1
2021-04-07 20:27:47.979 T:13774 WARNING <general>: CDVDMessageQueue(audio)::Put MSGQ_NOT_INITIALIZED
2021-04-07 20:27:52.737 T:5089 INFO <general>: CActiveAESink::OpenSink - initialize sink
2021-04-07 20:27:52.738 T:5089 INFO <general>: CAESinkALSA::Initialize - Attempting to open device "hdmi:CARD=AMLMESONAUDIO,DEV=0"
2021-04-07 20:27:52.749 T:5089 INFO <general>: CAESinkALSA::Initialize - Opened device "hdmi:CARD=AMLMESONAUDIO,DEV=0,AES0=0x04,AES1=0x82,AES2=0x00,AES3=0x00"
2021-04-07 20:27:52.750 T:5089 INFO <general>: CAESinkALSA::InitializeHW - Your hardware does not support AE_FMT_FLOAT, trying other formats
2021-04-07 20:27:52.751 T:5089 INFO <general>: CAESinkALSA::InitializeHW - Using data format AE_FMT_S16NE
2021-04-07 20:30:13.933 T:5089 INFO <general>: CActiveAESink::OpenSink - initialize sink
2021-04-07 20:30:13.934 T:5089 INFO <general>: CAESinkALSA::Initialize - Attempting to open device "hdmi:CARD=AMLMESONAUDIO,DEV=0"
2021-04-07 20:30:13.947 T:5089 INFO <general>: CAESinkALSA::Initialize - Opened device "hdmi:CARD=AMLMESONAUDIO,DEV=0,AES0=0x04,AES1=0x82,AES2=0x00,AES3=0x00"
2021-04-07 20:30:13.948 T:5089 INFO <general>: CAESinkALSA::InitializeHW - Your hardware does not support AE_FMT_FLOAT, trying other formats
2021-04-07 20:30:13.948 T:5089 INFO <general>: CAESinkALSA::InitializeHW - Using data format AE_FMT_S16NE
2021-04-07 20:30:15.105 T:5056 INFO <general>: VideoPlayer::OpenFile: pvr://channels/tv/Svi%20programi/pvr.hts_1630659906.pvr
2021-04-07 20:30:15.121 T:13774 WARNING <general>: CDVDMessageQueue(audio)::Put MSGQ_NOT_INITIALIZED
2021-04-07 20:30:15.172 T:5152 INFO <general>: Skipped 1 duplicate messages..
2021-04-07 20:30:15.172 T:5152 WARNING <general>: xbmc.translatePath is deprecated and might be removed in future kodi versions. Please use xbmcvfs.translatePath instead.
2021-04-07 20:30:16.124 T:13774 INFO <general>: Creating InputStream
2021-04-07 20:30:16.131 T:13774 INFO <general>: Creating Demuxer
2021-04-07 20:30:16.131 T:13774 INFO <general>: Closing stream player 2
2021-04-07 20:30:16.132 T:13879 ERROR <general>: Got MSGQ_ABORT or MSGO_IS_ERROR return true
2021-04-07 20:30:16.132 T:13879 INFO <general>: thread end: video_thread
2021-04-07 20:30:16.132 T:13774 INFO <general>: waiting for video thread to exit
2021-04-07 20:30:16.132 T:13774 INFO <general>: deleting video codec
2021-04-07 20:30:17.253 T:13774 INFO <general>: Opening stream: 1001 source: 256
2021-04-07 20:30:17.253 T:13774 WARNING <general>: OpenStream - Unsupported stream 1001. Stream disabled.
2021-04-07 20:30:17.254 T:13774 INFO <general>: Opening stream: 1002 source: 256
2021-04-07 20:30:17.254 T:13774 INFO <general>: Finding audio codec for: 86016
2021-04-07 20:30:17.254 T:13774 INFO <general>: CDVDAudioCodecFFmpeg::Open() Successful opened audio decoder mp2
2021-04-07 20:30:17.254 T:13774 INFO <general>: Creating audio thread
2021-04-07 20:30:17.254 T:14010 INFO <general>: running thread: CVideoPlayerAudio::Process()
2021-04-07 20:30:17.254 T:13774 INFO <general>: Opening stream: 1006 source: 256
2021-04-07 20:30:17.254 T:13774 INFO <general>: Opening stream: 1003 source: 256
2021-04-07 20:30:17.255 T:13774 INFO <general>: waiting for teletext data thread to exit
2021-04-07 20:30:17.256 T:13774 INFO <general>: Creating teletext data thread
2021-04-07 20:30:17.260 T:14011 INFO <general>: running thread: CDVDTeletextData
2021-04-07 20:30:17.365 T:13774 INFO <general>: Opening stream: 1001 source: 256
2021-04-07 20:30:17.365 T:13774 INFO <general>: CVideoPlayerVideo::OpenStream - Creating codec: 27
2021-04-07 20:30:17.365 T:13774 INFO <general>: DVDVideoCodecAmlogic: Opened Amlogic Codec
2021-04-07 20:30:17.366 T:13774 INFO <general>: Creating video thread
2021-04-07 20:30:17.366 T:14012 INFO <general>: running thread: video_thread
2021-04-07 20:30:17.366 T:13774 INFO <general>: Opening stream: 1002 source: 256
2021-04-07 20:30:17.366 T:13774 INFO <general>: Finding audio codec for: 86016
2021-04-07 20:30:17.367 T:13774 INFO <general>: CDVDAudioCodecFFmpeg::Open() Successful opened audio decoder mp2
2021-04-07 20:30:17.367 T:13774 INFO <general>: Closing stream player 3
2021-04-07 20:30:17.367 T:13774 INFO <general>: Opening stream: 1006 source: 256
2021-04-07 20:30:17.367 T:13774 INFO <general>: Opening stream: 1003 source: 256
2021-04-07 20:30:17.367 T:14012 INFO <general>: DVDVideoCodecAmlogic::AddData Open decoder: fps:25/1
2021-04-07 20:30:17.371 T:14010 INFO <general>: Creating audio stream (codec id: 86016, channels: 2, sample rate: 48000, no pass-through)
2021-04-07 20:30:17.376 T:5089 INFO <general>: CActiveAESink::OpenSink - initialize sink
2021-04-07 20:30:17.381 T:5089 INFO <general>: CAESinkALSA::Initialize - Attempting to open device "hdmi:CARD=AMLMESONAUDIO,DEV=0"
2021-04-07 20:30:17.397 T:5089 INFO <general>: CAESinkALSA::Initialize - Opened device "hdmi:CARD=AMLMESONAUDIO,DEV=0,AES0=0x04,AES1=0x82,AES2=0x00,AES3=0x02"
2021-04-07 20:30:17.399 T:5089 INFO <general>: CAESinkALSA::InitializeHW - Your hardware does not support AE_FMT_FLOAT, trying other formats
2021-04-07 20:30:17.399 T:5089 INFO <general>: CAESinkALSA::InitializeHW - Using data format AE_FMT_S16NE
2021-04-07 20:30:17.489 T:5152 WARNING <general>: xbmc.translatePath is deprecated and might be removed in future kodi versions. Please use xbmcvfs.translatePath instead.
2021-04-07 20:30:18.150 T:14012 INFO <general>: Skipped 2 duplicate messages..
2021-04-07 20:30:18.150 T:14012 WARNING <general>: OutputPicture - timeout waiting for buffer
2021-04-07 20:30:18.401 T:5056 INFO <general>: VideoPlayer::OpenFile: pvr://channels/tv/Svi%20programi/pvr.hts_1587284816.pvr
2021-04-07 20:30:18.416 T:14012 WARNING <general>: OutputPicture - timeout waiting for buffer
2021-04-07 20:30:18.519 T:5152 WARNING <general>: xbmc.translatePath is deprecated and might be removed in future kodi versions. Please use xbmcvfs.translatePath instead.
2021-04-07 20:30:18.555 T:13774 INFO <general>: Creating InputStream
2021-04-07 20:30:18.565 T:13774 INFO <general>: Creating Demuxer
2021-04-07 20:30:18.565 T:13774 INFO <general>: Closing stream player 2
2021-04-07 20:30:18.566 T:13774 INFO <general>: waiting for video thread to exit
2021-04-07 20:30:18.566 T:14012 ERROR <general>: Got MSGQ_ABORT or MSGO_IS_ERROR return true
2021-04-07 20:30:18.566 T:14012 INFO <general>: thread end: video_thread
2021-04-07 20:30:18.566 T:13774 INFO <general>: deleting video codec
2021-04-07 20:30:18.574 T:13774 INFO <general>: Closing stream player 1
2021-04-07 20:30:18.574 T:13774 INFO <general>: Waiting for audio thread to exit
2021-04-07 20:30:18.576 T:14010 INFO <general>: thread end: CVideoPlayerAudio::OnExit()
2021-04-07 20:30:18.576 T:13774 INFO <general>: Closing audio device
2021-04-07 20:30:18.578 T:13774 INFO <general>: Deleting audio codec
2021-04-07 20:30:18.579 T:13774 INFO <general>: Closing stream player 3
2021-04-07 20:30:18.579 T:13774 INFO <general>: Closing stream player 4
2021-04-07 20:30:18.579 T:13774 INFO <general>: waiting for teletext data thread to exit
2021-04-07 20:30:18.579 T:14011 ERROR <general>: Got MSGQ_ABORT or MSGO_IS_ERROR return true (-1)
2021-04-07 20:30:18.579 T:14011 INFO <general>: thread end: data_thread
2021-04-07 20:30:18.754 T:5089 INFO <general>: CActiveAESink::OpenSink - initialize sink
2021-04-07 20:30:18.755 T:5089 INFO <general>: CAESinkALSA::Initialize - Attempting to open device "hdmi:CARD=AMLMESONAUDIO,DEV=0"
2021-04-07 20:30:18.769 T:5089 INFO <general>: CAESinkALSA::Initialize - Opened device "hdmi:CARD=AMLMESONAUDIO,DEV=0,AES0=0x04,AES1=0x82,AES2=0x00,AES3=0x00"
2021-04-07 20:30:18.771 T:5089 INFO <general>: CAESinkALSA::InitializeHW - Your hardware does not support AE_FMT_FLOAT, trying other formats
2021-04-07 20:30:18.771 T:5089 INFO <general>: CAESinkALSA::InitializeHW - Using data format AE_FMT_S16NE
2021-04-07 20:30:19.638 T:13774 INFO <general>: Opening stream: 1001 source: 256
2021-04-07 20:30:19.639 T:13774 WARNING <general>: OpenStream - Unsupported stream 1001. Stream disabled.
2021-04-07 20:30:19.639 T:13774 INFO <general>: Opening stream: 1002 source: 256
2021-04-07 20:30:19.639 T:13774 INFO <general>: Finding audio codec for: 86018
2021-04-07 20:30:19.640 T:13774 INFO <general>: CDVDAudioCodecFFmpeg::Open() Successful opened audio decoder aac
2021-04-07 20:30:19.640 T:13774 INFO <general>: Creating audio thread
2021-04-07 20:30:19.641 T:14023 INFO <general>: running thread: CVideoPlayerAudio::Process()
2021-04-07 20:30:19.821 T:13774 INFO <general>: Opening stream: 1001 source: 256
2021-04-07 20:30:19.821 T:13774 INFO <general>: CVideoPlayerVideo::OpenStream - Creating codec: 173
2021-04-07 20:30:19.821 T:13774 INFO <general>: CBitstreamConverter::Open Invalid hvcC
2021-04-07 20:30:19.821 T:13774 INFO <general>: DVDVideoCodecAmlogic: Opened Amlogic Codec
2021-04-07 20:30:19.821 T:13774 INFO <general>: Creating video thread
2021-04-07 20:30:19.821 T:14024 INFO <general>: running thread: video_thread
2021-04-07 20:30:19.822 T:13774 INFO <general>: Opening stream: 1002 source: 256
2021-04-07 20:30:19.822 T:14024 INFO <general>: DVDVideoCodecAmlogic::AddData Open decoder: fps:50/1
2021-04-07 20:30:19.831 T:5152 WARNING <general>: xbmc.translatePath is deprecated and might be removed in future kodi versions. Please use xbmcvfs.translatePath instead.
2021-04-07 20:30:19.833 T:14023 INFO <general>: CDVDAudioCodecFFmpeg::Open() Successful opened audio decoder aac
2021-04-07 20:30:19.833 T:14023 INFO <general>: Creating audio stream (codec id: 86018, channels: 2, sample rate: 48000, no pass-through)
2021-04-07 20:30:19.838 T:5089 INFO <general>: CActiveAESink::OpenSink - initialize sink
2021-04-07 20:30:19.839 T:5089 INFO <general>: CAESinkALSA::Initialize - Attempting to open device "hdmi:CARD=AMLMESONAUDIO,DEV=0"
2021-04-07 20:30:19.852 T:5089 INFO <general>: CAESinkALSA::Initialize - Opened device "hdmi:CARD=AMLMESONAUDIO,DEV=0,AES0=0x04,AES1=0x82,AES2=0x00,AES3=0x02"
2021-04-07 20:30:19.854 T:5089 INFO <general>: CAESinkALSA::InitializeHW - Your hardware does not support AE_FMT_FLOAT, trying other formats
2021-04-07 20:30:19.855 T:5089 INFO <general>: CAESinkALSA::InitializeHW - Using data format AE_FMT_S16NE
2021-04-07 20:30:20.157 T:5152 WARNING <general>: xbmc.translatePath is deprecated and might be removed in future kodi versions. Please use xbmcvfs.translatePath instead.
The moment where audio doesnāt initialize is 2021-04-07 20:27:44.068. The same channel is reopened at 2021-04-07 20:30:18.401 and it works just fine. Not sure if the differences in audio codec are the reason for it happening, but it worked just fine the next time.
Not really a critical bug, but its annoying.
Full log attached below.
Thank you in advance. Great work on Matrix!
kodi.log (1011.5 KB)
Hello Guys. I have a Vontar X3 media box (Amlogic S905X) and Iāve installed CoreELECV 19.1 Matrix on a microSD. Everything looks ok except the sound. I have a sound on the TV through HDMI, but I want to have sound on my AVR through SPDIF. The AVR supports AC-3 and DTS, no HD sounds. The problem is that when I enable passthrough in CoreELEC, thereās no sound on the AVR. I followed the instructions in KODI wiki, but still no luck. It suggest to disable āSync playback to displayā, but this option is missing from CoreELEC 19.1 Matrix in my box. Any suggestion how to solve or how to find this option? It should be under Settings/Player/Videos.
Please ssh into your device and run the command ce-debug and paste the result here.
Hello. This is the output:
