No log, no problem
When no logs are provided there are no problems!
Use this how-to to create some useful and needed debug logs:
https://wiki.coreelec.org/coreelec:troublesteps
X96MAX PLUS Q2 very slow boot from emmc
CEC Not Working On 9.2.7
Dramatic Wifi slowdown 19.3-Matrix
CoreELEC 19.1-Matrix_rc2 Discussion
Looking for users with no working WiFi or BT
IR Remote not working until ir-keytable gets executed
CoreELEC 19.1-Matrix_rc1 Discussion
Orbsmart S86 Pro - Bluetooth problems
Khadas VIM3L IR and CE 19.X
9.2.4.2 Discussion
KM9 Pro Classic - Android 10 Factory ROM - Coreelec wont boot
X96 mini remote went retrograde after 19.1
VIM3 PRO no network
Do amlogic-ng builds work well on GXL(S905X/S905D/S905W) devices?
Coreelec crash with sonos arc
CoreELEC 19 Matrix Discussion (Kodi RC)
Widevine CDM install issue - running out of memory?
MECOOL M8S Plus DVB S905D - tuner not found
Coreelec does not boot in X96 mini
9.2.4.2 Discussion
Coreelec problems
Fake 4Gb RAM?
9.2.4.2 Discussion
Compile driver
ODroid C4 stop going to sleep
TX95 Amlogic S905X hangs on playback start (9.2.3 only)
CoreELEC 19.2-Matrix_rc3 Discussion
X96 mini Power Off not working
9.2.5 Discussion
No signal with resolution.ini in place (9.2.5)
Bl301 injection can kill your box
9.2.4.2 Discussion
Nightly builds
[S905X3] Evolveo Multimedia Box C4
IPTV simple client loading problem
Gt king pro slows down after suspend
Switching back from AMREMOTE to MESON-IR
Old remote or sonys remote
No access to repo (connexion OK)
CoreELEC 19.4-Matrix_rc2 Discussion
Amlogic S905X3, S905Y3, S905D3 thread
9.2.5 Discussion
CoreELEC 19.2-Matrix_rc2 Discussion
Hk1 box Hyperion
Eminent EM7680
What's powering off my device?
Bl301 injection, problems, help,
9.2.6 Discussion
9.2.6 Discussion
9.2.6 Discussion
9.2.6 Discussion
Tvheadend-stream
Matrix memory usage
CE Matrix 19.2 RC3 - VDR Backend / VNSI client
Frame Rate issue
9.2.6 Discussion
19.0-Matrix Discussion
9.2.6 Discussion
9.2.6 Discussion
9.2.7 Discussion
CEC stopped working
Wireless remote not working on coreelec19
Sbc banana pi bpi-m5
No device reboot from Kodi menu
Coreelec 9.2.5
Ugoos AM6 B plus - no audio passthrough option
A95X F3 Air Feedback Install CE
No audio out Ugoos AM6B+
Repository for AmRemote & Meson IR Remote Controllers
IPTV Big problem! 9.2.8 and 19.3 dont scan
Spidev @ Khadas vim3
CoreELEC 19.4-Matrix_rc3 Discussion
DTB for g12b_w400_4g (tv box s922x)
Tvheadend client better through wifi than Ethernet
VIM3L using MCE remote
Playlist Issues
X96 max+ revision AI - ICPlus_IP1001 (lan is not working)
Coreelec9.2.5
CoreELEC 19.1-Matrix_rc4 Discussion
X96 Max Plus - intermittent black screens during playback
