CoreELEC 19.1-Matrix_rc3 (April 26th, 2021)
CoreELEC 19.1-Matrix_rc3 is now available. It was a rather short development cycle this time around, which saw the CoreELEC developers focusing on fixing the most common issues reported with the 19.1-Matrix_rc2 release.
INFO: Release is currently on hold and update paused!
If the system request a update to rc3 do not update!!
Remove the rc3 by SSH:
cd .update
rm -rf *
sync
Or just by enter the CE samba shared folder Update and remove any file in there.
Changes Since 19.1-Matrix_rc2
- Updated Wifi driver QCA9377
- Implemented Wifi driver QCA6174
- Implemented RTL8761B Bluetooth device
- Updated Wifi driver ssv6xxx-aml
- Implemented Wifi driver SSV6030P
- Add option for Khadas VIM3(l) to switch wired network interface from ‘default’ to ‘M.2 Slot’
- Fix LPCM with some AVRs and set the correct codec for DTS-HD
- Add an option to allow playing DTS-HD as LPCM
- CoreELEC-settings: add option to backup thumbnails
- Kodi: add option to disable DTS-HD Core fallback
Downloads:
- Click here
Discussion thead:
- Click here
