CoreELEC 19.1-Matrix_rc4 (April 28th, 2021)
CoreELEC 19.1-Matrix_rc4 is now available. This is a hotfix release for issues on some type of hardware introduced by 19.1-Matrix_rc3 release.
Changes Since 19.1-Matrix_rc3
  • Added dt_id device specific option for dtb-xml
Changes Since 19.1-Matrix_rc2
  • Updated Wifi driver QCA9377
  • Implemented Wifi driver QCA6174
  • Implemented RTL8761B Bluetooth device
  • Updated Wifi driver ssv6xxx-aml
  • Implemented Wifi driver SSV6030P
  • Add option for Khadas VIM3(l) to switch wired network interface from ‘default’ to ‘M.2 Slot’
  • Fix LPCM with some AVRs and set the correct codec for DTS-HD
  • Add an option to allow playing DTS-HD as LPCM
  • CoreELEC-settings: add option to backup thumbnails
  • Kodi: add option to disable DTS-HD Core fallback
Downloads:
Discussion thead:
