Please use this thread for general 19.1-Matrix_rc4 discussion
Khadas VIM3l users
Please be sure you have a file /flash/dtb.img on your current eMMC installation before upgrade to CoreELEC-19-Matrix! Otherwise the device will stop booting and a recovery will be needed!
Open a SSH connection and check it by:
CoreELEC:~ # ls /flash/dtb.img
/flash/dtb.img
If the output look like this the system is compatible and can be upgraded to CoreELEC-19-Matrix. If you get a “file not found” please restore your system like with a Android image or a compatible krescue image before upgrade! Please keep in mind the VIM3L HTPC kit is including a not official image by Team CoreELEC so maybe it does not support the upgrade as well.
As I wrote wifi should work. It works on other devices but not on yours. So to get it working for you too you need to help us with some data. Or just live without. Or buy one device and send it to one of the devs.
Do you have the access point thing turned on the in CE wi-fi settings? Try turning it off and reboot and see if you can see some networks… I see nothing there if I have the AP thing turned on (since CE19, it worked ok CE 9), when I turn it off, they come up (using the Odroid wifi adapator (5, I think?))
Thank you. No problem to upgrade the ugoos am6 plus from rc2. This time I tried a Wireless connection. My AP uses the same SSID for both WiFi bands. At first, the ugoos connected to the 5 GHz band. But I had frequent buffering because there are several obstacles in between. Then I replaced the AP with another and the ugoos connected to 2.4 GHz and it was better, no more buffering as long as I played only full HD Blu-ray.
Is there a defined logic in CE to chose one or the other WiFi band or is this something at a lower level, out of (y)our control ?
If necessary, I can change the 5 GHz SSID to force the connection to 2.4 GHz.
