CoreELEC 19.2-Matrix Discussion
Hello, someone have the dtb tree of p281_gxl_4/32GB from Box D905 ???
Thank you.
@Portisch
ls .config/modprobe.d
blacklist.conf                   disable-spdif-for-hd-audio.conf
cat blacklist.conf
blacklist wlan
cat disable-spdif-for-hd-audio.conf
# INTEL HBR WORKAROUND FOR DTS-MA & Dolby TrueHD PLAYBACK
# Uncomment the following lines to disable any S/PDIF out to deliver
# bitstreamed audio on Intel builds. This is a rough workaround for
# users that have both S/PDIF and HDMI audio outputs on their motherboard
# or motherboard+discrete graphics combo.
# EVEN IF YOU ARE NOT USING THE S/PDIF OUTPUT
# but still have one, you will need to uncomment the lines below !
# after uncommenting these lines, you must reboot for these settings to take effect
# blacklist snd_hda_codec_realtek
# blacklist snd_hda_codec_sigmatel
# blacklist snd_hda_codec_cirrus
Did this information help you gleam any new ideas of what might be amiss with the blacklist between 19.2 RC3 and 19.2?
please also make a dmesg | paste as it’s not included in the log above, thx
@Portisch
As requested:
http://ix.io/3Ca0
Try blacklist wlan-qca9377-aml in your blacklist config.
@Portisch
That fixed it.
I guess the module name or the way it was being processed changed in the last revision.
Thanks for your help.
With the new 19.2 matrix the screen resolution 1024x768 disappeared. It is no longer in the menu.
Is there a trick to get it back ?
Thank you.
I have a Sunnzo S9 mini S905W.
My screen randomly goes pinkish/greenish. I have read in this forum that is is possible to add a RGB option in a file by sshing into the box. How to do that ?
Thank you.
Hi
Do you speak about this ? Color space issues - #6 by pierino2010
But I have brand new Sony TV and I have this issue too … I think there is nothing to do with RGB or something like …
I have sshed into my box and entered the 2 lines. I’ll tell you it this fixes the random pinkish/greenish display. My TV is 2010 Sony Bravia.
Thank you.
Edit November the 18th 2021
In Android box itself, I chose the RGB settings.
In CoreElec, I added the 2 mentionned lines in autostart.
Result : The pinkish/greenish colors have disappeared.
I have a 2020 SONY X900H and I have this issue too.
I did not tried this tweak for now because I’m not sure …
Does anyone know if this RGB issue also concerns the news TV ? like news 2020/21 Sony TV ?
Good news about Atmos dropouts: Kodi 19.3 already out with those fixes Kodi 19.3
And it’s already in CE nightlies.
OK wait and see for 19.3 instead of 19.2 8-))
19.3-Matrix is released, please continue here:
