Please use this thread for general 19.3-Matrix discussion
With CoreELEC, Kodi GUI doesnt show CPU Frequency information since Matrix (skin hides those labels, if doesnt get CPU freq.)
Its most likely due to changes, which somehow stop using /sys/devices/system/cpu/cpu0/cpufreq/cpuinfo_cur_freq
Leia: xbmc/CPUInfo.cpp at Leia · xbmc/xbmc · GitHub
Matrix: xbmc/CPUInfo.cpp at Matrix · xbmc/xbmc · GitHub
Is there any hope for patch inside CE? (I dont have time to look at this more deeply yet)
NIce work guys.
No probs here, Free Guy with the high bitrate plays fine now…
Wow. That was quick. Looks like I can Can revert back to the main build again rather than my own fork. It was a good learning experience which may help me contribute to the projects properly in the future.
Where should this CPU Frequency information be in skin?
Propably it will not be only place (I guess in some OSD/debug could be there also), but for sure its in the System Information - Hardware tab (I am using that tab for checking CPU minimum settings when Idle)
https://i.imgur.com/GEtDFvW.png k18
https://i.imgur.com/8VSa7Pp.png k19
I was really excited to see a fix for hickups in TrueHD audio in Kodi 19.3. I assume this fix made it into CoreELEC 19.3 as well? Because unfortunately I still get audio hickups after updating CE. I’m running CE on a VIM3.
In the playerprocessinfo, like in this CPU Speed…
It’s normally displayed in CE 19.3_Kodi Matrix.19.3 with default Estuary skin with slightly modded
DialogPlayerProcessInfo.xml: ScreenShot
How about your HW info tab?
There is no CPU Freq info, and not in default CE Estuary skin…
It would be nice if someone could check on x86_64 Linux. Because I don’t see this option on LibreELEC running in virtual machine.
Good point, “pure” linux with Kodi (Kodi or Libreelec) is unfortunatelly platform, which I dont have to try, I just assumed from clean Kodi on Win that Kodi generally is OK itself.
From what I see Kodi shows different things on arm/aarch64 than on Linux and Windows. The reason is here: xbmc/GUIWindowSystemInfo.cpp at Matrix · xbmc/xbmc · GitHub
Removing #if gives wanted result:
So it is not CE issue
