Experience some fps problems at 19.2. Sometimes if I continue a tv series or movie, the fps is not right and I recognize micro stutter, if I press 10 sec forward the screen goes black (a sign that he change the fps) and all is good. same if I start the movie or series from beginning. Someone has this too?! I have all settings like ever, that kodi recognize the fps with a delay of 2 sec.
I tested the Rii x1 wifi with no issue, I just typed the full alphabet on a PVR search with no long presses.
Martin
Probably is my Rii mini i8+ or itās WiFi dongle behaving differently than your Rii x1, since itās a nightmare to use it on CE 19.x versions. It annoys me so much that I switched from CoreElec-Kodi to Firestick 4k Kodi, where my Rii mini i8+ works properly.
What long key should I test? Typically with a keyboard you donāt need any long keys?
Martin
Oh Sholander, thatās a knife through the heart. And Kodi in firestick is so badā¦
Well you can have longpress if you mask eventlircd and use amremote or rc_maps. Kodi only supports longpress if the remote acts as a keyboard. It is possible in CE. We wonāt hold you at CE if you are unhappy. FireTV is a nice device.
The remote I am talking about IS a wireless keyboard Rii mini i8+ working over WiFi USB dongle.
And Iām staying on CE since N2 is not my only Amlogic device
Yes, but FireStick 4k is my main Kodi provider which I use in my holiday place; no smart TV there and certified L1 comes in handy. So instead of resting in my drawer and waiting for next holiday season I put it to use ![]()
Btw, I would not know much about FSās Android since from the first day I use Kodi as my FS launcher, so no mess with Android nor with Amazonās crap. And Kodi 19.2 on FS 4k works same as on my other devices, PC, Laptop, and 3 Android boxes; not to mention that my WiFi keyboard works perfect on all mentioned, except on my N2.
Itās not long keypress thatās bothering me (although I use them a lot) but short or normal keypress is my problem. I have to press the key VERY short to get proper reaction, and if Iām not fast enough I get unintentional long keypress reaction or repeated characters when typing.
Hallo,
mein A95X max Bluetoogh funktioniert immer noch nicht.
Wlan Lan ok
gibt es eine Lƶsung?
grüsse
Hi there,
my A95X max Bluetoogh still does not work.
Wlan Lan ok
is there a solution?
regards
Try this solution. No idea if it works or not.
Place this file in \\BOX_IP\Configfiles\udev.rules.d folder, reboot and check if something changed or not
70-input-repeat.rules (232 Bytes)
Also try with this content in file:
Please inform us if one or both of them works.
Thanx, will do today and inform you.
Well, both files work and improve/slower key response. I kept the first/shorter one, and transferred the dongle from back 3.0 port to the front 2.0 port and the keyboard is again very usable.
Thank you very much for help.
Can you put the Firestick back in the drawer to use only in vacations?
I already did that, put it into deep sleep
unfortunatelly HDMI passthrough of AC3 is still broken on M8S II Mini. Any idea how to fix it? Iām back to 9.2.8 for the time being since it is working fine there.
I have an a95x box (s905x) that I use a 8812BU based AC wifi USB adapter as it is much faster than the onboard N wifi.
On older CE versions I had to disable the onboard wifi or neither the onboard or the USB adapter would work if they were both plugged in/active at the same time.
After installing the latest update I an unable to disable the onboard wifi using the blacklist.conf file, and neither wifi adapter works at boot if the USB adapter is plugged in.
I had previous added āblacklist wlanā to my blacklist file, and it worked without issue.
I can confirm that those files are in place, and my black list appears unchanged from previous versions.
If I look at lsmod I donāt see any name changes that jump out at me.
Module Size Used by
ir_rc6_decoder 16384 0
ir_nec_decoder 16384 0
ir_lirc_codec 16384 0
lirc_dev 24576 1 ir_lirc_codec
meson_ir 16384 0
rc_core 40960 6 ir_rc6_decoder,ir_nec_decoder,ir_lirc_codec,meson_ir,lirc_dev
hci_uart 86016 1
btbcm 16384 1 hci_uart
btqca 16384 1 hci_uart
btintel 24576 1 hci_uart
bluetooth 425984 27 hci_uart,btintel,btqca,btbcm
wlan 4198400 0
88x2bu 2981888 0
mali 348160 1
joydev 24576 0
nfsd 364544 3
exportfs 16384 1 nfsd
nfs_acl 16384 1 nfsd
wireguard 139264 0
ip6_udp_tunnel 16384 1 wireguard
wifi_dummy 16384 0
amvdec_vp9 135168 0
amvdec_vc1 69632 0
amvdec_real 45056 0
amvdec_ports 249856 0
v4l2_common 16384 1 amvdec_ports
videobuf2_dma_contig 20480 1 amvdec_ports
videobuf2_memops 16384 1 videobuf2_dma_contig
v4l2_mem2mem 28672 1 amvdec_ports
videobuf2_v4l2 28672 2 amvdec_ports,v4l2_mem2mem
videobuf2_core 49152 3 amvdec_ports,v4l2_mem2mem,videobuf2_v4l2
amvdec_mpeg4 65536 0
amvdec_mpeg12 110592 0
amvdec_mmpeg4 40960 0
amvdec_mmpeg12 49152 0
amvdec_mmjpeg 36864 0
amvdec_mjpeg 40960 0
amvdec_mh264 172032 0
amvdec_h265 163840 0
amvdec_h264mvc 57344 0
amvdec_h264 151552 0
amvdec_mavs 61440 0
amvdec_avs 69632 0
amvdec_avs2 221184 0
stream_input 208896 12 amvdec_h265,amvdec_mavs,amvdec_mh264,amvdec_h264mvc,amvdec_ports,amvdec_real,amvdec_vp9,amvdec_h264,amvdec_avs2,amvdec_mpeg12,amvdec_avs,amvdec_mmpeg12
decoder_common 196608 18 amvdec_h265,amvdec_mavs,amvdec_mjpeg,amvdec_mh264,amvdec_mmpeg4,amvdec_h264mvc,amvdec_mmjpeg,amvdec_ports,amvdec_real,stream_input,amvdec_vp9,amvdec_h264,amvdec_avs2,amvdec_mpeg12,amvdec_avs,amvdec_vc1,amvdec_mmpeg12,amvdec_mpeg4
firmware 28672 18 amvdec_h265,amvdec_mavs,amvdec_mjpeg,amvdec_mh264,amvdec_mmpeg4,amvdec_h264mvc,amvdec_mmjpeg,decoder_common,amvdec_real,stream_input,amvdec_vp9,amvdec_h264,amvdec_avs2,amvdec_mpeg12,amvdec_avs,amvdec_vc1,amvdec_mmpeg12,amvdec_mpeg4
media_clock 45056 14 amvdec_h265,amvdec_mavs,amvdec_mh264,decoder_common,amvdec_ports,firmware,stream_input,amvdec_vp9,amvdec_h264,amvdec_avs2,amvdec_mpeg12,amvdec_avs,amvdec_vc1,amvdec_mpeg4
amlvideodri 24576 0
videobuf_res 16384 1 amlvideodri
videobuf_core 32768 2 amlvideodri,videobuf_res
videodev 290816 6 amlvideodri,v4l2_common,amvdec_ports,videobuf2_core,v4l2_mem2mem,videobuf2_v4l2
media 40960 1 videodev
fuse 131072 1
fbcon 61440 0
bitblit 16384 1 fbcon
softcursor 16384 1 bitblit
font 20480 1 fbcon
I tried upgrading to the 10/18/21 nightly, and it has the same issue.
I rolled back to 19.2 RC3 and was able to get everything working without issue again. I am guessing something changed between RC3 and the final release that impacted blacklisting the wifi somehow.
Does anyone have any ideas on how I can disable the onboard wifi adapter again without a hardware modification to the system?
your blacklist config would be needed. and also provide all debug logs
@Portisch
I provided the blacklist config in my post, but I will put it in code brackets so it is easier to find.
blacklist wlan
Here are debug logs.
http://ix.io/3C6J
please also:
ls .config/modprobe.d
and then cat for each conf file you get:
cat .config/modprobe.d/xxxx.conf
