And this is the crash log from a second machine.
https://drive.google.com/file/d/10LlLpLQYBzO-914CjaW_z0Umg9Fnks4A/view?usp=sharing
So it seems not im the only one with this issueā¦
@franko12345 please try with a clean - fresh install. You have a lot of repos/addons installed what maybe cause this issue. Then install addon after addon and test if it breaks the system.
@hyena you need to provide logs to request support/help and also for you: try again with clean - fresh install!
EDIT:
@franko12345 @hyena please try this test image if the issue is solved:
https://mega.nz/file/OOwS2TbA#yELkTBXmoeLveLdaQozamwjU-NRJuHk4gDa8yLbQN6s
Update by SSH:
cd .update
megadl https://mega.nz/file/OOwS2TbA#yELkTBXmoeLveLdaQozamwjU-NRJuHk4gDa8yLbQN6s
sync
reboot
And then try also if Netflix/Amazon whatever is still working, thank you.
I wanted to know if there will be a new release of coreelec v19 (matrix) for old amlogic processor as the nightly build is laggy and canāt be install on emmc
no information, no help:
Continues to be rock solid on my S905X - X96 2/16 (android 7.1 bootloader). Upgraded from .tar, previously using a nighty build circa mid May. No issue with the upgrade process.
On a 40 minute test run:
Updated widevine. Netflix content continues to play happily.
NAS content on NFS and SMB Shares play.
Happyness continues.
I think with my particular usage needs and the overall stability of the current state of CE, Iāll be permanently moving my daily drivers up to 19.x. Fantastic!
Thanks, once more, tireless Developers.
@kshi can you test this image as well if NF still play with latest widevine 4.10.2252.0 library?
Hi, can someone confirm that āplay nextā or ānext trackā is broken?! Song back or Chapter back works. But on remote CEC and on screen (see pic) it wonāt work. Only in the App over WLAN it works.
@Portisch, Absolutely! Iāll do it once Iām home.
I have seen this to and I think this is a kodi bug. I also maybe remember a PR at xbmc what is about this issue.
Performed upgrade on two different devices (A95X-F2 and X96Max Plus).
Both devices now experience random device rebooting without any reason (both during playback and in idle mode).
Please try with this image:
After i reinstall the 19.2 the problem is back.
You can find my crash log in the link this below.
http://hyena.myasustor.com:8000/portal/apis/fileExplorer/share_link.cgi?link=N4uokFVZgKxWg-Dfwu91Rg
Are you sure this is build from above?
Because in log file I see
Kodi compiled 2021-05-31
Also post kodi crashlog when it happens.
Can anybody confirm simpleiptv issue? If it does not work, I donāt want this update until fixed
For me it works just as before all older versions.
Iptv simple works just fine here.
Have you read what was said? It installed. Depending on the build you upgrade from you may have to install some of the addons related individually. But thatās all
I donāt understand. Dependencies broken or not? Somebody has reported simpleiptv addon fails to install because of broken dependencies. I need to be sure, because itās most important addon in my case.
Read everything, it was easily solved
