CoreELEC 19.2-Matrix_rc2 Discussion
Need some informations. I am now on 9.2.7 version. Can i update to 19.2 Matrix . Is the chipset supported ?
Guess what, we need some informations too, like which chipsets?
Sorry forgot , i own MINIX NEO U9 -H SOC Amlogic S912-H
Are you using same SD card on both devices?
Yes i do and i do not want to loose that option
on sd side i have coreelec. On internal storage emmc Android
I see there are other questions, but let me share my research with you. It happened again, and here’s what I can read as it happened :
http://ix.io/3uOC
2021-08-02 19:35:31.185 T:4917    ERROR <general>: [ script.embuary.helper ] Image error: Could not get image for image://video@smb%3a%2f%2f192.168.1.50%2fSgt_8To%2fFILMS%2fGemini%20Man%20(2019)%20(HDR%2060ips).mkv/ (try 3) -> [Errno 2] No such file or directory: '/storage/.kodi/userdata/addon_data/script.embuary.helper/img/tmp/cc5e398c2fa91ba680f34a64ef0960f8.jpg'
2021-08-02 19:39:41.574 T:4811     INFO <general>: CVideoPlayer::CloseFile()
2021-08-02 19:39:41.575 T:4811     INFO <general>: VideoPlayer: waiting for threads to exit
2021-08-02 19:39:46.112 T:5145     INFO <general>: CVideoPlayerAudio::Process - stream stalled
2021-08-02 19:39:50.563 T:5142     INFO <general>: CVideoPlayer::OnExit()
2021-08-02 19:39:50.563 T:5142     INFO <general>: Closing stream player 1
2021-08-02 19:39:50.563 T:5142     INFO <general>: Waiting for audio thread to exit
2021-08-02 19:39:50.568 T:5145     INFO <general>: thread end: CVideoPlayerAudio::OnExit()
2021-08-02 19:39:50.569 T:5142     INFO <general>: Closing audio device
2021-08-02 19:39:50.574 T:5142     INFO <general>: Deleting audio codec
2021-08-02 19:39:50.574 T:5142     INFO <general>: Closing stream player 2
2021-08-02 19:39:50.574 T:5142     INFO <general>: waiting for video thread to exit
2021-08-02 19:39:50.574 T:4819     INFO <general>: CActiveAESink::OpenSink - initialize sink
2021-08-02 19:39:50.604 T:5144     INFO <general>: thread end: video_thread
2021-08-02 19:39:50.604 T:5142     INFO <general>: deleting video codec
2021-08-02 19:39:50.608 T:5142     INFO <general>: Closing stream player 3
2021-08-02 19:39:50.660 T:4819     INFO <general>: CAESinkALSA::Initialize - Attempting to open device "surround71:CARD=AMLAUGESOUND,DEV=0"
2021-08-02 19:39:50.667 T:4819     INFO <general>: CAESinkALSA::Initialize - Opened device "surround71:CARD=AMLAUGESOUND,DEV=0"
2021-08-02 19:39:50.670 T:4819     INFO <general>: CAESinkALSA::InitializeHW - Your hardware does not support AE_FMT_FLOAT, trying other formats
2021-08-02 19:39:50.670 T:4819     INFO <general>: CAESinkALSA::InitializeHW - Using data format AE_FMT_S24NE4
2021-08-02 19:39:59.862 T:5143    ERROR <general>: Read - Error( -1, 110, Connection timed out )
2021-08-02 19:39:59.862 T:5143    ERROR <general>: Process - <smb://192.168.1.50/Sgt_8To/FILMS/Gemini Man (2019) (HDR 60ips).mkv> source read failed with -1!
2021-08-02 19:40:59.921 T:4811     INFO <general>: VideoPlayer: finished waiting
2021-08-02 19:40:59.922 T:4811     INFO <general>: CVideoPlayer::CloseFile()
2021-08-02 19:40:59.922 T:4811     INFO <general>: VideoPlayer: waiting for threads to exit
2021-08-02 19:40:59.922 T:4811     INFO <general>: VideoPlayer: finished waiting
2021-08-02 19:40:59.956 T:4811    ERROR <general>: GetString: error reading /sys/class/amhdmitx/amhdmitx0/custom_mode
What does this mean ? Whole of informations in LOG
Yes, exactly the same. I directly transfer it to the new Vim3 pro to test.
You mean physically same SD card? Or you have two same cards and both devices are on.
Coreelec is on microSD, on internal is Android? can we install CoreELEC 19.2 (Kodi 19) to Minix U9-H ?
I only have one microSD card for two Vim3 Pro
  • I put the card in the first Vim3 Pro : everything works
  • I put this same card in the second Vim3 Pro : the videos crash after 2 min
S912 isn’t supported in Amlogic-ng and Matrix. You’ll have to stay in 9.2.7.
Topic closed as rc3 is available:
