CoreELEC 19.5-Matrix_rc2 Discussion
HK ON2 Kodi forum
AML S922X includes the 9th Generation Advanced AMLogic TruLife Image Engine that can (depends on OS & Firmware):
• Support Dolby Vision (Optional), HDR10, HDR10+, HLG HDR and Prime HDR processing
• Motion compensated noise reduction and 3D digital noise reduction for random noise
• Block noise, mosquito noise, spatial noise, contour noise reduction
• Motion compensated and motion adaptive de-interlacer
• Edge interpolation with low angle protection and processing
• 3:2/2:2 pulldown and Video on Film (VOF) detection and processing
• Smart sharpness with SuperScaler technology including de-contouring, de-ring, LTI, CTI, de-jaggy, peaking
• Dynamic non-Linear contrast enhancement
• 3D LUTs with 17x17x17 nodes, provide 4913 different control points, which is competent for matching calibrated displays to a target colorspace
• High precision HSL color space-based color management with low saturation protection, independent luma/hue/saturation adjustment to achieve blue/green extension, fresh tone correction, and wider gamut for video
• 2 video planes and 3 graphics planes
• Independent HDR re-mapping of video and graphic layer
deinterlace is always on on aml
it is even forced on progressive on some formats
ok, cool! thanks for the info. this helps.
I have a problem that if the bluetooth headphones are paired, they connect to me automatically, even if I disable it in the CoreElec settings.
Odroid N2
CoreELEC 19.5rc2 new install
Previously used the last legacy build.
Issue movies scrapped in with either database are not showing all the tags like audio info video info 4k , 3d etc in movies view some are displayed but many are not.
I have tried deleting library and scanning in again same thing happens.
No issues if scanned in on older version.
Extract video information from files is enabled
If anyone has any suggestions please let me know thanks.
Tried a fresh install again same issue with python scrapper but non python works perfectly
Try with nightly, try with CE-20.
Kodi 19 Matrix become near end of live cycle.
Thanks I will I did not have much luck with this version it crashed on me a few times stopped responding I even tried a brand new SanDisk sdcard never had that with the 9.2.8 so not meant to be. I’ll try latest and keep the 9.2.8 as a safe backup on other card. Thanks
Closed, please continue here:
