Nice, but the download link for 19.5-Matrix_rc2 takes you to 20.0-Nexus_alpha2 (Stable).
Looks like the script on the server is too smart
Please use this until itās fixed:
Why remove the auto color detection? It sounded usefulā¦
Please read the news againā¦
Oh āreworkedā, weird i was sure it said āremovedā
Just installed on an old X96 S905x, so far no issues.
å®č£
ēēę¬CoreELEC-Amlogic-ng.arm-19.5-Matrix_rc2-Generic.img.gzļ¼dtbęÆsc2_s905x4_4g_1gbit.dtbļ¼Uēåå
„EMMCåŗéļ¼ä»£ē ļ¼No CoreELEC installation found on eMMC
Install in dual boot mode, CoreELEC and Android on eMMC
Use CoreELEC data from
Install in single boot mode not possible!
No DT partition was found Please choose one option? [1/2]: 1
Free space of 'partition CE_FLASH': 512MB
mount: mounting /dev/loop1 on /media/CE_STORAGE failed: Invalid argument
Error running pclose on cmd: `mount -o rw,loop /dev/loop1 /media/CE_STORAGE`. Error: 255 Error executing cmd 'mount -o rw,loop /dev/loop1 /media/CE_STORAGE'
Failed to mount 'CE_STORAGE' partition!
Failed to read free space of partition 'CE_STORAGE'!
Failed to create new partition table!
ę±č§£ēęä¹å¤ēļ¼č°¢č°¢ļ¼
ceemmc wonāt work on the > Android 11 firmware found on these s905x4 boxes for now, on which the system(super) and storage (userdata) partitions are newer ext4 fs either created from underlying device-mapper or stored directly on these partitions yet not readable for the 4.9 kernel CE is currectly using.
Also, to keep the new partitoon table from being reverted back, ceemmc has to remove the partitions node from dtb so the u-boot wonāt āhelpfully fixā the partition table, which is also not doable for these S905X4 boxes which must read the partition node in dtb instead of the partitoon table to get the location for several partitions, so removing the node will brick the boxā¦
You could find some other ways to install to internal for these boxes not supported by anyone especially teamCE, but I donāt recommend even trying to install to emmc on S005X4 boxes for now.
As per documentation:
After the upgrade to 19.5-Matrix_rc2 on Odroid-N2 two lines on boot screen:
[INFO] Skipped Optee TEE-Suplicant
[DEPEND] Dependency failed for Amlogic OPTEE Video Firmware Preload Service.
Is it possible to get it rid?
And what does it means?
āOptee TEE-Suplicantā service (opentee_linuxdriver.service) is skipped since the condition is not met:
And āAmlogic OPTEE Video Firmware Preload Serviceā (video-firmware-preload.service) failed to start since it requires opentee_linuxdriver.service:
Since these two services are only used for S905X4 for now you can simply disable these services if youāre not using a S905X4 device:
systemctl disable opentee_linuxdriver.service
systemctl disable video-firmware-preload.service
Ops⦠it doesnāt work on my N2:
CoreELEC (official): 19.5-Matrix_rc2 (Amlogic-ng.arm)
MyN2:~ # systemctl disable optee_linuxdriver.service
Failed to disable unit: Unit file optee_linuxdriver.service does not exist.
MyN2:~ # systemctl disable video-firmare-preload.service
Failed to disable unit: Unit file video-firmare-preload.service does not exist.
MyN2:~ #
Sorry Iāve mistyped the service names, they should be opentee_linuxdriver.service and video-firmware-preload.service, Iāve editted my original post
nope, it doesnāt work, I mean: commands executed without any output so probably successfully but after N2 reboot still those two lines are on TV screen.
If you really need to hide messages then mask both services:
systemctl mask opentee_linuxdriver.service
systemctl mask video-firmware-preload.service
And looks like we could improve this two scripts to not show anything in any case.
Iām getting HDMI sync issues on my Odroid N2+ with RC2.
As soon as anything is displayed at 2160p (even the UI) my projector will lose signal and resync every ~10 seconds.
I downgraded to RC1 and the issue is gone. Any ideas?
