Thanks for answering. Here I show how a terrestrial television channel does not show signal quality level. Satellite only works with this new CoreELEC version.
Friendforum, which tuner are you using? And which driver you have selected?
And both signals workimng on CE 9.2?
if you use, skin.nox.glass replace the font I have broken the view for pvr signal info and weather widget ā¦
I was looking for information on your problem and I donāt see any other options for satellite and terrestrial TV
PVR.ActStreamProgrSNR
PVR.ActStreamProgrSignal
You will find it in DialogPlayerProcessInfo.xml
Line: 582 and 612
you can experiment.
I have nothing that shows the signal in pvr, I use online tv from the m3u list and I am not able to check it.
Thanks, Aeon Nox Glass works great on the new CoreELEC version. Some small details are missing but everything is fine.
** Happy new years**
Hi, installed on SD card on Tanix T3 mini.
One issueā¦cannot connect to SSH, get connection refused error.
So far everything else working.
Spinecho, can you copy here text from your ssh client when you are trying to connect?
Not explicitly. Hiwever, when Iām done watching whatever Iāve intended to watch, I turn off the TV and CEC shuts the receiver down and presumably puts the box to sleep. The next time I turn the TV on the reverse happens and the box springs back to life and ready to rock. What I have noticed with CE 19, just from being too lazy to reboot the box, is that the Netflix add-on seems to work without a reboot, which wasnāt always the case with 9.x.x. NFS and SMB shares are certainly functional after waking, at least in the time it takes for me to wade through the UI to get to them. I honestly wish my use case was a little more exotic so I could more meaningfully test stuff.
Yes sadly, and I never found a good reason why itās not enabled by defaultā¦
Because users exposes devices to Internet with default password. Enabling ssh on first boot is good enough I think.
Yes, perfectly sane default I think
@kshi Thanks, your feedback was helpful. It tells me CEC and Suspend/Resume are both working on your devices.
After the installation finishes, what is the difference from user enabled or default to ON ?
Difference is that user has a choice. If itās on with default password ācoreelecā and someone access it without users permit itās our fault. Other way around it is on the user enabling a dangerous admin shell without changing the password. BTW the first time in the wizard you enable it gives you a chance to change the password.
OK, that I understand, and finally makes sense to meā¦, Iām a bit slow as time goes by
The new year splash screen message on latest nightly was awesome. Thanks
Spinecho, try again with next nightly with this commit: https://github.com/CoreELEC/CoreELEC/commit/d5888e9767ad3ecb6ebc6718c45774dbf3fb18d8
I think it should be made tomorrow.
I see them on Kodi 19 only. I also found a public stream triggering it: https://popcorntimes.tv/de/m/klfFG5A/der-gestiefelte-kater
