You can just let them be for the moment and decide in a case by case while detecting some problem while normal using CE. There are some add-ons, like Netflix or Prime that need the new Matrix repos.
Could I flag up that the Busy Box Keyboard selection in the CoreELEC options needs to display the âlong namesâ for the keyboard types i.e. country, region etc, rather than the short codes its displaying at the moment
No, it uses the original names from the keymap structure:
If you want to change it you might try your luck at LibreELEC: https://github.com/LibreELEC/service.libreelec.settings
So far so good.
My box its S905X2: Ugoos X2 Cube. Installed dual boot Android and CE Matrix on eMMC.
80% of time working as transport for LAN music/movie sources in CE.
20% of time working with HBO GO/Prime/Tidal on Android.
In plus:
Music scrapers working much much much better. Now its usable. I dont know its bauce of new Generic scraper or because of pythion 3.
In minus:
I use my TV remote with CEC which is working well.
As i choose shut down command in menu power box hibarnates/suspends. So i cannot shut it down. Of course i cannot wake box up. In ANY of versions of CE (from 9.2.1 stable and nightlies) i couldnt wake up box in CE. Cannot connect ssh or trying WOL.
I cannot turn on BL301. Shows me Error 251. Below inject and update logs.
inject_bl301.zip (2.1 KB)
So after update to eMMC all working very well. With these exceptions. Good job!
Did not find Amlogic image header magic! Error - exit!
Your bootloader is encrypted, no way to inject bl301, no way to solve your wake up issue by CE.
Contact your vendor to provide a fix, thank you.
Thank You for answer! I feedback to vendor.
EDIT.
@Portisch
But what about that unabling to turn off using Shutdown command in Power section?
Why you think your device do suspend instead power off? When you have it correctly adjusted at the CEC settings it works as it should.
Kodi Matrix works great with Mecool KI Pro. Everything but WiFi was tested and Matrix works as good or better than Kodi Leia.
I was wondering, is there anywhere I can check out the source code for CoreELEC Matrix versions? It looks like GitHub doesnât contain any matrix branches? I am trying to debug some of my own code and Iâd like to see what has changed from Amlogic to Amlogic-ng update (also Leia to Matrix changes).
Thank you for great work!
Source code will be available when things move past beta testing.
It seems most of my goofy glitchy issues with the Matrix beta were due to trying to import a recovery via CoreELEC. I hope these get settled out when Matrix comes out of beta. Starting from plain scratch it seems to work fine and smoothly on the Odroid N2.
@Portisch Thanks for the links, have the spare time but my programming skills are not up to the task.
in this new version I get the image quality satellite signal levels used in with SAT-IP I only get signal quality on the satellite television channels, on the terrestrial signal no info data television channels, does anyone know if it can be fixed? I have used several Skin and the same. Thank you.
Friendforum, you also doesnât see it on default Estuary skin? And which PVR addon you are using?
The CEC suspend and wake up option finally works on my box (s905x3)! It never worked before.
It is seen in the skin that it brings by default. I use Skin Estuary MOD and Aeon Nox Glax which give a detailed look. I use Tvheadend Mecool SAT-IP signal to X96 Air. The detail of the satellite signal is fine but the terrestrial signal shows nothing.
Thank you, Great Work
Lucky You! On my s905X2 never worked.
Which box do You have?
Friendforum, then I think th problem is with TVH addon.
A cheap X96 MAX 2/16GB with s905x3. Now I turn on my TV and the box wakes up
12.29 CE 19 Nightly Glides like a hot knife through butter on my N2+, N2, and X96 S905x.
- Netflix add-on in Matrix seems to work better than it ever has (havenât bothered to try on the S905x)
- Prime Video works
- NFS and SMB shares gleefully deliver their respective content with no issues that I could notice, 4K, HDR, garbagy old SD shit that I canât (wonât) get rid of, all play just fine.
- My Skin of choice is already supported (Aeon Nox 5 Silvo)
- No issues with CEC performance as connected to my archaic Yammy receivers and LG C9, CX.
- My beloved CBC add-on has already been updated to work in Matrix.
- No issues with Ethernet, though I expected nothing less, iperf testing over the network delivers near identical results to stable builds.
- As far as my limited use cases are concerned, this build could easily be swapped with the stable build I have on emmc as a daily driver.
If this is the state of the âbetaâ, the future is looking very promising!
Thanks Devs and Happy New Year everyone!
