But if you have a working internal installation with ssh you might be able to copy those files with ssh to the attached sd card with your Matrix installation from within CE.
Understood, I’ll see what I can do, thanks
I find the easiest way to copy & move files is to connect over your network using coreftp lite.
I using sftp.
Matrix installed, remote working, but tvheadend doesn’t detect TV adapters.
Time to close this thread and use newer one: 19.0-Matrix Discussion
