26-02-2022 Warehouse connections in the night version are not working. I can never install from a warehouse.
Itâs corrected in tomorrowâs nightly.
The upload error in the post-update stores continues.
31-03-2022 Night version boot remains on the logo.My device gt king pro
I tried both with update and clean installation
No ssh connection so you can make a log?
And debug kodi.log?
Yes, looks kodi issue, not kernel.
Yes, the system file has worked when the old was replaced (24-03-2022 SYSTEM file )
Itâs latest Kodi Nexus nightlies thatâs causing this problem since last week, so wait for a fix. Same thing on Android versionsâŚ
Kodi Nexus will work tomorrow again with next nightly
@Portisch Thanks for information
Samba did not work in 2022420.
There is unresolved issue with samba which doesnât show shares. But samba itself works if you add folder name to IP address.
//IP/folder
Releases ¡ fandangos/Kodi-HDR-Edition ¡ GitHub maybe you can use this for aarch64 with dolby vision support?
Hello, can CoreELEC 20.0-Nexus Alpha1 run on Vim4 ?
It does run yes.
Excellent, letâs go for the test. Thank you for your work. (No installation possible by OOWOW yet, I imagine ?)
Possibly never.
Not yet, weâll see if thatâs possible. I guess there will be an image there officially or unofficially.
The development is centered on making the video/audio stuff working. The rest will come (or not) later.
